Standard Range 0-60 mph?
nash_diego
San Diego, CA
F-150 Lightning, Model 3, Pacifica Hybrid
Anyone know the Standard Range's realworld 0-60? I've seen a lot of "this is what Ford says" or "estimated to be at" and a lot of hearsay, but no realworld data on the Standard Range's 0-60. I know the Extended Range is coming in faster than advertised and I hope the same is true for the Standard Range. I've seen posts where people say it's pretty close to the Extended Range's but no good data/tests that I've seen.
RavenYZF-R6
Denver
Tacoma
A few YouTubers have done 0-60 tests. Watch some vids on the SR pro or XLT. There is a variation to the times which is to be expected with location and weather as well as what type of equipment used.
GarageMahal
JT
2023 Lightning XLT SR - Iconic Silver
Data Wrangler
One example here (3.9 seconds!) but I am also looking to get more concrete numbers..
FordLightningMan
Upstate New York
F150
The only number I saw in a video was 3.9 seconds on the pro, I believe using a Dragy to measure. I have not seen a 0-60 on a SR XLT yet. I am skeptical 3.9 is consistently achievable, I'll be using my Dragy to test as soon as I get my truck
It's odd how little data is out there for this spec, no one is really testing the figure. Maybe this has to do with how few SRs are on the road, versus ER.
nash_diego
nash_diego
San Diego, CA
That's my thoughts as well. Most of the deliveries up to this point were extended range. But a lot of standard ranges are about to drop in the next few months. So I'm sure we'll be getting data shortly.
gorwell
Sacramento
Ioniq 5 / XLT Standard
Can someone explain to me why this matters?
How many of you are drag racing your F150?
nash_diego
nash_diego
San Diego, CA
Fun. And overall maneuverability like getting into and out of traffic, avoiding collisions.
I routinely floor it in my Model 3 for the reasons above.
I likely will at least once. It is a Lightning - high performance road racing truck.
And whether it is 3.8 or 3.9 or 4.0 makes such a noticeable difference... ;)
PA Lightning
Tbone
PA
Lightning Pro
I drove my dealer's SR Lariat. I can't give you zero to 60 in seconds, but it is wicked fast at half pedal. I would not want to stomp it. I know a lot of people do, but half pedal throws you back in your seat
XLT Jeffy
Vancouver, BC
2022 Ford Lightning XLT SR
After dailying my winter beater the past 8 months I'll be looking forward to blasting in my XLT SR.
Dirtyrider89
Korey
Ohio
F150
Technician for cranes
I seen one youtuber do 4.4 in the pro redline reviews
That's absurd. Anyone knows you don't stomp on the EV accelerator unless you are already back in your seat... :p
FlasherZ
St. Louis Metro
Me too. I have found that compared to my Model S, you can't be as aggressive with lane-changing with the Lightning. :)
PopsGG
Gerardo
San Diego, CA
F150 Lightning Lariat ER
You can clearly see in the video there is a grade change in the road ahead of them. This likely means they were at a slight decline for the test, which explains the sub 4 second result.
