boggle
Understandable. I spent quite a bit of time ensuring the design is pretty dynamic anticipating such a request, I'll see what I can do. In theory I should be able to just shift the whole thing down the requisite distance to be flush and the insert should rebuild itself. Will just need to see how much interference the shifter has with the tub and see if it even makes sense to do so.
Thank you for your efforts and thorough explanation. That makes sense. I'm pretty adamant in wanting to retain the Work Surface as I use that often and see this shifter knob potentially allowing me to have the work surface down while driving (occasionally my passenger likes to have a laptop on it, facing them).
I did also think about a multibody version of @ENDianDigital design for those of us with smaller build volumes. Figured you could just split the thing in half and weld it together with some MEK and hot staples. Tub shell in his design seemed plenty thick enough, could also increase the # of shells/infill at the point the two bodies make contact. Also surprised nobody has tried to vapor smooth one of these yet.
