Tesla Semi updated specs
jpepper07
Joshua
Ohio
2013 Ford F150
So every 3.5 hours they stop for 30 minute charge? Would also need super chargers at every big trucker gas station or rest stop to support it. I assumed they would make big use of trailers with batteries in them to make 10 hour drives.
I'm guessing that weight would be too much to offset hauling that much battery around. I believe the majority of the initial buyers are not necessarily long-haul truckers. Likely trucks that would find themselves back at a base each night. It's been a while since I've seen a list of buyers.
FlasherZ
St. Louis Metro
It works fairly well with federal CDL rules. 11 hours max driving in a 14 hour work shift, then 10 hours off. From the DOT's point of view, getting small chunks of rest makes sense while charging.
LightningShow
MA
'22 Lariat ER
Product Development
How fast do truckers drive where you are?
jpepper07
Joshua
Ohio
2013 Ford F150
I assumed 300 miles ÷ 70 mph is 4.28 hours. I then assumed they wouldn't charge above 85% and that they would aim for 70% charge in 30 minutes. So I dropped it to 3.5 hours. Very reasonable when you have energy loss and you want to charge before you hit 0% and when you are close to a charger.
Tony Burgh
Tony
Western Pennsylvania
22 Lariat ER
If their 300 miles of capacity is like mine, they’ll get 240 miles with no load. maybe 120 miles w a load.
LightningShow
MA
'22 Lariat ER
Product Development
The mileage spec is with an 82k pound load.
The powertrain is interesting - listed as 3 motors on the rear axles. I recall the early prototypes had 4 motors, one per rear set of wheels. They were Model 3 motors.
bryan995
François
San Diego
F150 Lightning
Yes I think this is suited for short hauls - not super long haul routes. Plus the specs are with 82,000 lbs of towing. It likely gets what, 2000 miles of range without a trailer ? For 150k - incentives it’s a F150L platinum killer for sure :)
Makes you wonder if the Tri Motor cyber truck may be coming back :)
LightningShow
MA
'22 Lariat ER
Product Development
Reasonable assumptions but probably closer to worst case than average case. It’s difficult to maintain an average travel speed of 70mph. I just made 190 mile drive at the maximum possible speed the highway would allow, with cruise on between 78-85mph. There were no slowdowns, construction or traffic and my door to door average speed was only 66mph. A tractor trailer will probably be more like 55mph in typical driving conditions. Perhaps in the plains states they might get a bit higher average. Up and down the coasts, probably even lower than 55mph.
vandy1981
Tennessee
Plumber
This semi is ideal for depot-to-depot deliveries. Like a UPS shipment from the Louisville distribution center to a local distribution hub in Nashville.
They would have chargers at each depot so there would be no need for public infrastructure.
cvalue13
Austin, Texas
‘22 Lightning ER Lariat
Fun-Employed
no doubt the ideal use case pending larger infra
for that matter, if I won Powerball I’d have one to haul a half dozen gated saddle mules to nowhere/anywhere in particular
  • Love
Reactions: GDN
vandy1981
Tennessee
Plumber
Sure, but you'd have to paint it like this:
Ford F-150 Lightning Tesla Semi updated specs 1661011473700
