K6CCC
- First Name
- Jim
- Sep 12, 2024
- Glendora, Calif.
- 2024 Lightning Flash ER in Antimatter Blue w/9.6 PPO , 2017 Corolla (wife's car)
- Occupation
- Retired from 2-Way radio systems
impossible. The CCS-1 standard has a max current of 500 amps. With our slightly less than 400 volts, that means we max out at a bit under 200 KW charge rate.If our ER batteries could maintain 400 kwh
With that said, as i understand it, the large battery version of the Silverado has two battery packs that run in parallel for driving and switch to series for charging - resulting in a just under 800 volt pack. 500 amps at 800 volts is 400 KW. Assuming that information is correct, an elegant solution to a faster charge.
