Stage3Motorsports
Arizona
2021 F150 STX CrewCab 4x4
Jake123
Jake
Eau claire wi
2021 f150
Power linemen
But when will any 2.5 coil overs or uca's be available for a 2021! :(
Sergeant Gearhead
Missouri
Ford
I'm in full agreement about the tires. If you off-road consistently, a set of tires that are better than the stock all-seasons are a smarter choice.
Johnny Tsunami
Johnny
2021 F-150 XLT POWERBOOST
Anyone know what kind actual lift I would get on a Fx4? Most say I wont get the full spec lift because of the offroad package. I want to make sure my tire will fit.
UNIKRN150
Bob
Pacific North West
Pinto SE 4x4
My 1st "mod" will definitely be disabling "Auto stop-start" and "Cylinder Deactivation" until my engine is broken in. In fact, I'll do it before I even leave the dealer's lot and here's how... (in case you didn't know, and care)
dhectorg
NA
Bilstein 6112 leveling kit for 2021 F150?
Stage3Motorsports
Stage3Motorsports
Arizona
Unfortunately release of new products is still unknown as delays of regular production have extended lead times on new releases as well. As soon as we get word we will certainly update the community.
What tire are you looking to run?
There unfortunately is no release date yet that I am aware of for the 6112 but as soon as I get some information I will absolutely share with the community.
Frank
Tizzzo
Ed
2021 Lead Foot Gray XLT 5.0 Supercrew 4x4
Veteran
That is actually only for auto start stop not cylinder deactivation unfortunately, it'll probably be something we can disable thru forscan or tune in the near future when they can crack the pcm.
UNIKRN150
Bob
Pacific North West
Pinto SE 4x4
Could be but these guys make a good case for it disabling Cylinder Deactivation.
Doesn't mean it's true.
Since everyone says it's very difficult to tell when Cyl Deact kicks in, without schematics it's going to be hard to tell if it actually works.
Maybe someone with aftermarket exhaust can try it and let us know. That seems to be the only way to really tell when it's kicking in.
Regardless... Auto Start-Stop isn't something I want my new engine doing either. But for that I can (& will) get this:
https://www.autostopeliminator.com/.../products/2021-ford-f-150-autostop-eliminator
Looks fairly easy to install.
I don't want to permanently disable cylinder deactivation anyway. Just during break in.
boo radley
ed
KS
1987 F150 1992 F150, 1999 F150, 2004 F150, 2013 F150
Seems only logical that Stop/Start will eventually wear the starter out prematurely.
I mean, Ford does some stupid things like EGR bolts coming loose on new 3.0 Power Strokes and going in the motor. Or, in my case, finding out that my 13 water pump impeller was plastic and shattered into a hundred pieces inside the coolant runs. Im still not positive that I got all the pieces out before installing a new pump.
Tizzzo
Ed
Veteran
They stated in an updated video that it doesn't work for cylinder deactivation as well as others reporting the same. Bummer for us 5.0 guys but I'm sure a fix will be coming soon, for now sport mode it is!
wayne
wayne
northern calif
2021 f150 platinum loaded, 2013 raptor
will pulling the plug on cylinder deactivation work on the power boost engine?
Johnny Tsunami
Johnny
Frank
Im looking to run a Nitto Ridge Grappler 285/75/17
Mud89
Rick
22 F150 5.0
Mechanic
So anyone have any idea if Forscan has the ability to disable cylinder deactivation? I have been told by someone that it’s possible.
