"Vehicle in Battery Saver Mode" Please drive
dmd3home
Central Coast CA
Lightning, Spark EV, Tesla Y, BMW X5 phev
But the truck wouldn't respond if it's in deep sleep....right? I can't do anything through the app at this point.
flyct
Jerry
South Florida
Blissfully Retired
Correct, you must manually start the truck to take it out of deep sleep after
Ford F-150 Lightning "Vehicle in Battery Saver Mode" Please drive IMG_0361
Ford F-150 Lightning "Vehicle in Battery Saver Mode" Please drive IMG_0364
watts/up
23 Pro SR
Correct. But I was curious if it was possible to bypass the app entirely. My shortcuts interact directly with Ford's servers via APIs, not the app. A long shot for sure, but it may work.
Ford F-150 Lightning "Vehicle in Battery Saver Mode" Please drive api
The TCU {on the truck} is shut down .... radio silence.... ain't nothing talking to it at this point.
Adventureboy
Ontario
You could probably use the app to turn on your climate control and run some of that battery down closer to 50%… you would have to do it many days/times but that might also solve both issues??
I don't think this will work. You can only use the climate control a few times before it forces you to use the start button.
dmd3home
Central Coast CA
I don't see how I can use it at all while in deep sleep mode....currently, the app does nothing. Deep sleep shuts down all communication.....in spite of batteries being fully charged.....dumb!
Mal106
Mal
SW VA
2025 Lightning Flash
Retired Pilot
The 12V battery is a weak point of hybreds, plug in hybreds and EVs. Also depleting a lead acid battery completely reduces its life, some say by 50%. Even 9.6v is damaging. Anecdotal evedence really isn't but I have personal experience with this problem with 3 makes and 4 models of vehicles. I'm all for the Lightning going incognito to save the 12v battery though good software could make the process far less likely with a full drive battery or plugged in.
