rugedraw
I can tell you with 100% confidence that code will prevent BC from working. That code references an old TSB citing outdated BC maps in the GWM. See attached.Still no BC maps. Do have this DTC (not on dash) after each trip:
Code: U2400 - Ethernet Failure With Gateway Module A (GWM)
Status (-2C):
- DTC Maturing - Intermittent at Time of Request
- Malfunction Indicator Lamp is Off for this DTC
Module: Image Processing Module A
Found a TSB for this code, but the fix doesn't fix it.
