2021-2022 F150 S3M 2.3" Offset Spacer Leveling Kit S3M-21LK1
Stage3Motorsports
Arizona
2021 F150 STX CrewCab 4x4
Now available and ready to ship!
Ford F-150 Lightning 2021-2022 F150 S3M 2.3" Offset Spacer Leveling Kit S3M-21LK1 {filename}
F150 Stage 3 2.3" Leveling Kit Features:
  • Adds front leveling without the hassles of taller kits
  • Provides 2.3" of front lift
  • Improves tire clearance and reduces rake
  • Offset design for more spring/UCA clearance and easier alignment
  • Heavy-duty steel construction with powder coat finish
  • Comes with Nylock nuts and instructions
  • Made in the USA
Provide Enough Front Leveling for Tire Clearance and Rake Reduction without Spring Contact Issues
The 2021-2022 F150s sit a bit different than the trucks that came before, and a lot of leveling kits on the market just don't quite give them the stance they need for a clean look and tire clearance while avoiding spring contact with the UCAs. The Stage 3 Motorsports 2.3" Offset Spacer Leveling Kit for 2021-2022 F150s provides the perfect amount front lift for your 2021-2022 F150 build while providing an issue-free ride that won't have you hating your truck. At 2.3" of front leveling, this kit leaves just a smidge of front rake while still providing the clearance you need to squeeze on larger tires and get a much more leveled look that is sure to turn some heads. Each spacer features an offset design that provides extra spring clearance and makes getting an alignment much easier after your installation. The Stage 3 2.3" leveling kit installs right onto your F150's stock front coilover assemblies without any permanent modifications, making them an easy suspension upgrade for your 2021-2022 F150.Heavy-Duty Steel Construction with Black Powder Coat Finish and Nylock Nuts for Install
The F150 2.3" Offset Leveling Kit is built tough, allowing it to handle just about any application you have in mind for your aggressive F150 build. Each spacer is manufactured out of 1/4" thick steel that's expertly welded together for a perfect fit onto your 2021-2022 F150. The spacers come topped off with a black powder coat finish that helps keep them protected from corrosion in practically any climate or application. The spacers install right onto your F150's stock coilover assemblies without stud trimming and come with a full set of Nylock nuts that hold them fast during even the roughest driving. The 2.3" leveling kit comes with instructions and is proudly made in the USA.
Fitment: 2021-2022 F150
Alignment recommended: while these spacer's offset design helps with alignment, we still recommend getting a four-wheel alignment in order to correct front toe angle in order to avoid excessive or strange tire wear.
Sethysan
Seth
North Carolina
2017 F-150
Healthcare
Long time customer with you guys, great to see your own line on this coming out!
Question...any chance of a Tremor in your fleet for testing with this kit? Haha
Stage3Motorsports
Stage3Motorsports
Arizona
We do not have a Tremor for testing, but give it time.
@Stage3Motorsports Does this work for the F150 Tremor models as well?
These will bolt on to a tremor, but the overall height achieved is unknown.
Graygoose2021
Central US!
2021 F150
Sales
Getting mine installed Wednesday!
travisN000
Travis
2021 F150 Powerboost, 2017 Ram 1500
Is there an explanation / diagram that demonstrates the "Offset design for more spring/UCA clearance and easier alignment"? How does this differ from any other spacer kit?
Graygoose2021
Central US!
2021 F150
Sales
Installed, installer loved the kit, said went on smoothly. Will get pics tonight.
jabrego
Jason
Los Angeles
2021 F-150 4X4 Lariat 501A Sport
Installed pics, HUGE difference!
Before and after.
Was the spacer 2.3”? Did you get a height increase of 2.3”. I read that the spacer is 1.5” but it gives you 2.3” height. Is that true? What are your heights(front & back)after install? I’M trying to decide what spacer to use. Your information would be appreciated.
Graygoose2021
Central US!
2021 F150
Sales
I believe it was measurement from base to top plate was 1.5, to give an overall 2.5 lift.
Mines a 2WD, so my measurements can be shorter than an FX4 packed truck. But I can surely get you measurements.
