2021 F150 Trail Armor Rocker Panel & Door Sill Guards
Stage3Motorsports
Arizona
2021 F150 STX CrewCab 4x4
Keep your truck protected, These areas are common for wear and tear from dirty shoes rubbing on them all the time.
2021 F150 SuperCab Trail Armor Rocker Panel & Door Sill Guards 14125
2021 F150 SuperCrew Trail Armor Rocker Panel & Door Sill Guards 14097
Ford F-150 Lightning 2021 F150 Trail Armor Rocker Panel & Door Sill Guards 1624400693204
Highlights:
  • Provides protection and a great look
  • Complete set of four door sill and rocker panel guards
  • Durable TPO construction
  • OEM-style matte black finish
  • Easy, drop-in installation
  • Backed by a limited lifetime warranty
Adds Door Sill and Rocker Protection in a Clean, Easily-Installed Package
2021 F150s that are going to see some serious use off-road or down at the job site always run the risk of getting a few dings, but you probably don't want to turn your F150's door sills or rocker panels into Swiss cheese. Bushwacker Trail Armor Rocker Panel Guards for 2021 F150s help prevent common dings and scratches from ruining your F150's good looks. Each Bushwacker Trail Armor Guard drops right onto your truck without the need for any drilling or permanent modifications and takes the dings and scrapes from common off-road and job-site use so that your truck's paint doesn't have to. Bushwacker's Trail Armor is a great way to keep your F150's rockers and door sills looking great, no matter what you decided to do with your awesome F150 build. Durable and Pliable TPO Construction with a Matte Black Finish
Bushwacker's Trail Armor is made out of high-quality, high-strength material and was carefully designed for a perfect, hassle-free fit. Each of the rocker panel guards is made out of a specialized TPO material that's soft and pliable, yet strong enough to not buckle under the bumps and scrapes, or rocks that you bring in on your boots. The Trail Armor Rocker Guards each have an OE-style matte black finish that looks great on practically any F150 paint color or styling theme. The Bushwacker Rocker Guards easily install using pre-applied 3M double-sided tape, and they require no drilling or other permanent modification to your truck. Bushwacker's Trail Armor Guards are made in the USA and come backed by a limited lifetime warranty.
Matthew2118
Matthew
2014 Ford Fiesta, 2021 Ford F-150 XL Powerboost
Will these still fit with Fords OEM black running boards being on the truck?
Stage3Motorsports
Stage3Motorsports
Arizona
