New York 2022 Ford F-150 Lightning Lariat
empirefordofhuntington
333 W Jericho Turnpike, Huntington, NY 11743, USA
www.empirefordofhuntington.com
MSRP 2022 Ford F-150 Lightning Lariat : $75,434
Exterior
Box Lighting-LedLarge Front Trunk AreaPower Adj/Heated/Power Fold Exterior Mirrors
BoxlinkLed Projector W/ Dynamic Bending HeadlampsPower Up/Down Front Hood
Headlamps - Auto High BeamLocking Removable Tailgate With Tailgate AssistPower Up/Down Tailgate
Headlamps - Autolamp (On/Off)Pickup Box Tie Down Hooks
Functional
360-Degree CameraFordpass Connect 4G Hotspot Telematics ModemPre-Collision Assist W/Aeb
B&O Sound System, 8 SpkrForward Sensing SystemSecuricode, Keyless Entry
Blis W/Cross-Traffic AlertIntell Adapt Cruise CtrlSelectable Drive Modes
Class Iv Trailer HitchLane-Keeping SystemSync4a W/Evr & 15.5" Scrn
Evasive Steering AssistPost-Collision Braking
Interior
10-Way Pwr Drv & Multi-Adj Pwr Frt PassA/C W/Dual Climate ControlHtd/Ventilated Frt Seats
12" Productivity ScreenAmbient LightingIlluminated Entry
1Touch Up/Down Dr/Pass WinAuto-Dim Rearview MirrorInterior Work Surface
60/40 Fold-Up Rear BenchHtd Str Whl W/Mnted CtrlsPedals - Power Adjustable
Sliding Rear Window W/ Defrost & Privacy Glass
Safety
Advanced Security PackAirbags - Safety CanopyPerimeter Alarm
Airbags - Front Seat Mounted Side ImpactLed Ctr High Mnt Stop LampSos Post-Crash Alert Sys
Specs
  • Mileage
    • EPA MPG Equivalent - City: 76
    • EPA MPG Equivalent - Hwy: 61
    • EPA MPG Equivalent - Combined: 68
    • Estimated Battery Range (mi): 230
  • Weight Information
    • Base Curb Weight (lbs): 6015
    • Gross Axle Wt Rating - Front (lbs): 3770
    • Gross Axle Wt Rating - Rear (lbs): 4900
    • Curb Weight - Front (lbs): 3129
    • Curb Weight - Rear (lbs): 2886
    • Gross Vehicle Weight Rating Cap (lbs): 8250
  • Trailering
    • Dead Weight Hitch - Max Trailer Wt. (lbs): 5000
    • Dead Weight Hitch - Max Tongue Wt. (lbs): 500
    • Wt Distributing Hitch - Max Trailer Wt. (lbs): 7700
    • Wt Distributing Hitch - Max Tongue Wt. (lbs): 770
    • Maximum Trailering Capacity (lbs): 7700
  • Suspension
    • Suspension Type - Front: Double Wishbone
    • Suspension Type - Rear: Trailing Arm
    • Spring Capacity - Front (lbs): 3770
    • Spring Capacity - Rear (lbs): 4900
    • Axle Type - Front: Independent
    • Axle Type - Rear: Independent
    • Axle Capacity - Front (lbs): 3900
    • Axle Capacity - Rear (lbs): 4150
  • Brakes
    • Brake Type: 4-Wheel Disc
    • Brake ABS System: 4-Wheel
    • Brake ABS System (Second Line): 4-Wheel
    • Disc - Front (Yes or ): Yes
    • Disc - Rear (Yes or ): Yes
    • Front Brake Rotor Diam x Thickness (in): 14
    • Rear Brake Rotor Diam x Thickness (in): 13.8
  • Tires
    • Front Tire Size: P275/60SR20
    • Rear Tire Size: P275/60SR20
    • Spare Tire Size: Full-Size
    • Front Tire Capacity (lbs): 4050
    • Rear Tire Capacity (lbs): 4498
  • Wheels
    • Front Wheel Size (in): 20 X 8.5
    • Rear Wheel Size (in): 20 X 8.5
    • Spare Wheel Size (in): Full-Size
    • Front Wheel Material: Aluminum
    • Rear Wheel Material: Aluminum
    • Spare Wheel Material: Aluminum
  • Steering
    • Steering Type: Rack-Pinion
    • Turning Diameter - Curb to Curb (ft): 47.8
  • Exterior Dimensions
    • Wheelbase (in): 145
    • Length, Overall (in): 231.7
    • Width, Max w/o mirrors (in): 79.9
    • Height, Overall (in): 77.2
    • Overhang, Front (in): 37.8
  • Cargo Area Dimensions
    • Cargo Box Length @ Floor (in): 66
    • Cargo Box Width @ Top, Rear (in): 65.2
    • Cargo Box Width @ Floor (in): 65.2
    • Cargo Box Width @ Wheelhousings (in): 51.1
    • Cargo Box (Area) Height (in): 21.4
    • Tailgate Width (in): 60.3
    • Cargo Volume (ft³): 52.8
  • Interior Dimensions
    • Passenger Capacity: 5
    • Front Head Room (in): 40.8
    • Front Leg Room (in): 43.9
    • Front Shoulder Room (in): 66.7
    • Front Hip Room (in): 62.5
    • Second Head Room (in): 40.4
    • Second Leg Room (in): 43.6
    • Second Shoulder Room (in): 66
    • Second Hip Room (in): 62.6
  • Summary
    • Vehicle Name: Ford F-150 Lightning
    • Body Style: SuperCrew Cab
    • Body Code: T
Empire Ford of Huntington is the one-stop dealership for any Ford & Lincoln needs in Huntington NY. We have new and used Ford and Lincoln, from sedans, passenger vans, convertibles, cargo vans, work trucks, to mini vans. In addition to wide selection of vehicles, trade appraisals, service and parts specials, and special financing programs, our Ford dealer also covers all your service and repair needs, from regularly scheduled appointments to major repairs.
We have highly trained and certified technicians to perform general automotive repair, preventative car maintenance, air conditioning and heater service, cooling system and radiator repair, synthetic motor oil replacement, oil filter replacement, brake repair, engine diagnostic, tune-up, batteries, headlights, transmission services, struts, all fluid level checks, and other repairs needed.
Ford F-150 Lightning 2022 Ford F-150 Lightning Lariat 2022 Ford F-150 Lightning images 1.PNG
