VTRedWingsFan
Just updated. So far so good.
Doesn't work??Finally had a reason to try the one time target charge slider during a mid-day charge. Still doesn’t work.
How long has this app been out for the lightning? Roughly 3 years?
Embarrassing.
so you’re able to start charging the truck via the app and select a battery percentage less than 100% via the slider after the charging has started?Doesn't work??
Really? I didn't know there was an existing problem, I have used it multiple times, had the truck only a week so far. Could there be a difference with firmware version or something?
Yes to both, did exactly this today - pulled out the phone, go to FordPass and hit the charge now - set it to 90% charge - all good it works.so you’re able to start charging the truck via the app and select a battery percentage less than 100% via the slider after the charging has started?
