tearitupsports
- First Name
- Russell
- Jun 1, 2024
- Houston, TX
- 2023 F-150 Lightning Lariat ER
- Occupation
- Industrial Automation & Controls
I have a LG Resu 16H battery I am giving away for free. The only caveat is that it has dipped below its minimum voltage to turn on by itself, and will need to go through some sort of charging procedure. It actually has never been cycled. I had the battery connected to my HIS at about 23% then shut the whole thing off for a month, but was not able to turn it back on because of the apparent self discharge.
Since the price of these has gone down since I purchased mine, and since it needs to be recharged I just have decided to give it away so I don't feel bad if for some reason it doesn't work out.
I have it packed in the original boxes and it has all manuals, templates and parts. Although I have the original pallet, I have no desire to pack it up for shipments, so I will only meet someone in the Houston area. It weighs over 300 lbs, and the batteries are over 100 lbs each.
Please note this is a 400V battery and is only compatible with some high voltage inverters like the Ford/Sunrun, or some others.
