Stage3Motorsports
With the limited availability of tires these days I figured I would bring some to the forum that are presently in stock and ready to ship.
If anyone is interested in a wheel and tire package shoot me a message.
Frank
LT315/70R17 BF Goodrich All-Terrain T/A KO2 Off-Road Tire 08806
Highlights:
If you want the capability of pushing your truck to some off-road extremes, you need to have the right equipment. BF Goodrich is one of the most trusted names when it comes to tires and now has created a buzz with their new All-Terrain T/A KO2 Tires. Whether you're ripping through the desert, blazing new trails through the forest, maneuvering sand dunes or going all-out by rock-crawling, these aggressive off-road tires will definitely get you where you want to go. The 315/70R17, All-Terrain T/A KO2 BF Goodrich Tire features a 20% tougher side wall than versions in the past as well as race-proven CoreGard Technology to take on the toughest road hazards with confidence. High-Quality Construction
The split and bruise resistant sidewall rubber on this tire is derived from BFGoodrich's race-proven Baja T/A KR2 tire. Adding a thicker, extended shoulder rubber down the sidewall helps to protect more of the critical sidewall failure zone. What this means is increased performance as well as longer tread-life which not only saves you money down the road but also extends your adventures on and off the road. Another great feature of these tires is their interlocking tread design which provides increased stability for more even wear over the long haul. This tread pattern rejects stones while the side walls help to clean-out and eject mud for when you're caught in the thick stuff. The beauty of the KO2 tire is that it strikes the perfect balance between the dependability you need for rugged trails and the menacing street look you want for every day street driving -- all while keeping excess tire noise to a minimum.
Tire Specs:
Frank
Highlights:
- 34.36" Diameter
- Versatile All-Terrain Tread Pattern
- Balanced On and Off-Road Performance
- Split and Bruise Resistant Sidewall
- Sold Individually
Tire Specs:
- Wheel Size: 17"
- Overall Tire Diameter: 34.36
- Max Load (single): 3195 lbs.
- Tire Size: 315/70R17
- Load Range: E
- Tread Depth: 15/32
- Sidewall Color: Black
