F-150 Prius
- First Name
- Adam
- May 12, 2021
- Silicon Valley
- 2021 F-150 Platinum PowerBoost FX-4 6½
- Occupation
- Software Algorithms
Does the BFG All-Terrain T/A K02 fit the 2021 F-150 Hybrid FX4 in 275/65R20?
The 275/60R20 is the direct replacement, the 65 is an inch larger overall diameter with much higher ratings and only 2lbs heavier with basically a half inch extra clearance at rated pressure or I guess higher sidewall when aired down. More is better. So I hope someone has already put these on and found they clear.
I'm open to recommendations (wheels and tires, but I'll probably get just tires for the winter, so quick-fit chains is my other question.)
https://www.tirerack.com/tires/tire...idewall=Blackwall&partnum=765SR0KO2&tab=Specs
https://www.bfgoodrichtires.com/auto/tires/all-terrain-t-a-ko2
