Sill Plates- Might want to pop them off and take a look if you have a spill
PA Lightning
Tbone
PA
Lightning Pro
Bad luck last week. Had two liquid leaks on passenger side floor liner. First one was from a pump sprayer. Even though I have the mud mats some of the liquid looked like it may have leaked under the sill plate. Popped off the sill plate. There is a wire chase there that was full of fluid.
By the time the soda can exploded a few days later I was a pro at removing the liquid.
Based on all of the electronics in the truck, I thought it would be a good idea to remove the liquid and dry it out.
I have the Pro model with the vinyl flooring and I do not know if the same thing would happen with the trims that have carpet.
21st Century Truck
Martin
Based on another thread here about corrosion in these sill channels, I sprayed the insides of mine with Amsoil Heavy Duty Metal Protectant I had left over from coating the underbody.
MaintGrl
Marsha
El Sobrante, Ca
Dis you by chance take pictures? Removal & sill trough?
