Madtroniks
Diamond Sponsor
Ford
You can check out the most recent Discount Tire Promotions plus local install options are available with having access to one of the best balancer on the market.
Discount Tire Current Promotions for Ford F-150 Lightning Tires.
Military or Discount Tire credit card members can save 5% on their purchase. You can read the additional terms how to verify military membership or financing / minimum amounts for credit card on their website.
5% Military Discount for Discount Tire - Thanks for your service.
In addition you can purchase Road Hazard warranty for your stock Ford F-150 Lightning tires since OEM tires do not come with Road Hazard warranty and also get lifetime road force balancing / rotations plus local install options available.
Rivian Forums Thread on PSA: Discount Tire / America’s Tire will sell Road Hazard warranty and lifetime Road Force Balancing with free rotation if you have < 2,000 miles
I love Hunter Road Force balancer pretty much available at most discount tires and most bays have now been converted. I remember the days when only 1 or 2 machines were road force balancer. Factories / high end tire shops uses a similar road force balancer to try to get the tires down into the teens for the least amount of steering wheel vibrations / body / seat vibrations.
Benefits of Road Force Balancing - Similar balancer High End shops use.
Make sure to use Road Force Balancing where you go and that should make a good difference in your driving experience.
Usually the best time I have seen to buy tires is around major holidays like our Federal Holidays. The next one coming up is Memorial Day and we should see some good sales / promotions which should stack.
Keep in mind install / lifetime balancing is around $25 per tire/wheel.
I would check the reviews on the forum for options other than stock tires especially if you're looking to get better range, better grip or off-road performance
The tires I personally like are Michelin, Pirelli, BFGoodRich, Toyo and GoodYear.
You can also schedule an appointment to make it easier to take care of installing your tires or doing tire rotations / balancing using the below link to make appointments.
Discount Tire Create Appointment Link for Install, Maintenance or to purchase Tire Protection Plan
PSA: You can get Tire protection for your stock tires at Discount Tire as well. I did this for my 20" All Terrains when R1S compact spare was out of stock initially in 2023.
I just recently purchase the newly released (April 2025) Pirelli XTM AT Electric Vehicle All Terrain Tire. You can see my reviews using the below links.
Ford F-150 Lightning Forum - Initial Review on Pirelli XTM AT
Ford F-150 Lightning Discount Tire Promotions, Road Hazard warranty and lifetime road force balancing / rotations plus local install options available. 1746634130364-4f
Ford F-150 Lightning Discount Tire Promotions, Road Hazard warranty and lifetime road force balancing / rotations plus local install options available. 1746636686577-v
Ford F-150 Lightning Discount Tire Promotions, Road Hazard warranty and lifetime road force balancing / rotations plus local install options available. IMG_4415
Ford F-150 Lightning Discount Tire Promotions, Road Hazard warranty and lifetime road force balancing / rotations plus local install options available. IMG_4418
Ford F-150 Lightning Discount Tire Promotions, Road Hazard warranty and lifetime road force balancing / rotations plus local install options available. IMG_4419
Ford F-150 Lightning Discount Tire Promotions, Road Hazard warranty and lifetime road force balancing / rotations plus local install options available. IMG_4408
Ford F-150 Lightning Discount Tire Promotions, Road Hazard warranty and lifetime road force balancing / rotations plus local install options available. Pirelli Order (2)
Ford F-150 Lightning Discount Tire Promotions, Road Hazard warranty and lifetime road force balancing / rotations plus local install options available. discount-tire-receipt-
This post and future posts may contain links to affiliate website, and we may receive a commission for any purchase made by you on the affiliate website. Our affiliates include GoAFFpro, CJ Publishing and Shareasale.
Madtroniks
Madtroniks
Diamond Sponsor
Ford
I swapped out the SL XTM AT with Toyo AT III EV SL to make sure I can safely inflate my vehicle to the minimum specs.
I would recommend waiting for the LT version of XTM AT which can handle more weight / pressure.
I chose the Toyo Open Country AT III EV tires because of the 116H rating / AT EV tires / Price.
I had to work with an associate at Discount Tire after ordering the tires to get them from a different store and have them shipped via Fedex next day at no charge. These SL tires are in low stock compared to the LT version
The 1-5 days shipping time was accurate for me. I did call my local store to make sure they can order it or get it from another warehouse / store.
Here is the initial pictures from the install.
Just driving 4 miles I got 1.92 mi per kWh. I would expect this to go up once I’ve driven 20+ miles instead of short trips.
I’ll drive more tonight and report back with proper efficiency numbers and once i get all tires to 50 lbs hot.
Ford F-150 Lightning Discount Tire Promotions, Road Hazard warranty and lifetime road force balancing / rotations plus local install options available. 1747412236011-tn-1-
Ford F-150 Lightning Discount Tire Promotions, Road Hazard warranty and lifetime road force balancing / rotations plus local install options available. 1747412357261-a9-1-
Ford F-150 Lightning Discount Tire Promotions, Road Hazard warranty and lifetime road force balancing / rotations plus local install options available. img_6315-jpe
Ford F-150 Lightning Discount Tire Promotions, Road Hazard warranty and lifetime road force balancing / rotations plus local install options available. img_6311-jpe
Ford F-150 Lightning Discount Tire Promotions, Road Hazard warranty and lifetime road force balancing / rotations plus local install options available. img_6317-jpe
Ford F-150 Lightning Discount Tire Promotions, Road Hazard warranty and lifetime road force balancing / rotations plus local install options available. img_6308-jpe
Madtroniks
Madtroniks
Diamond Sponsor
Ford
Took my car to Discount Tire for road force balancing and spoke to their lead technician about my concerns of high speed steering wheel shake around 60 mph - 80 mph along with vibration in the seat.
They did a solid job of getting the all terrain Toyo AT III EV tires balanced using Hunter road force balancer and used around half ounce weights - 1 oz and were able to get it down into the teens with 19 being the highest.
Makes a big difference not only in the wheel but also the seat. The back set were worse than the fronts from vibration standpoint.
Now it’s all buttoned up ready for a road-trip to Rivian Adventure Network.
More pictures to follow the next 2 weeks.
Discount Tire Current Promotions for Rivian Tires.
Discount tire is trained to work on Rivians and typically most stores have pucks to help lift your vehicle.
5% Military Discount for Discount Tire - Thank you very much for your service.
Benefits of Road Force Balancing - Similar balancer used by factories.
Ford F-150 Lightning Discount Tire Promotions, Road Hazard warranty and lifetime road force balancing / rotations plus local install options available. IMG_7125
Ford F-150 Lightning Discount Tire Promotions, Road Hazard warranty and lifetime road force balancing / rotations plus local install options available. IMG_7128
Madtroniks
Madtroniks
Diamond Sponsor
Ford
One of the best things about Discount Tire available for life of the tire is the free flat repairs, free rotations and free air check offered by a shop that has experience working on electric vehicles like Rivian, Ford and Tesla.
Lately with the weather I’ve been taking advantage of Discount Tire air check while on road trips.
Discount Tire July 4th Promotions
You can also schedule an appointment to make it easier to take care of installing your tires or doing tire rotations / flat repairs using the below link to make appointments.
Ford F-150 Lightning Discount Tire Promotions, Road Hazard warranty and lifetime road force balancing / rotations plus local install options available. 1751161508872-m1
Ford F-150 Lightning Discount Tire Promotions, Road Hazard warranty and lifetime road force balancing / rotations plus local install options available. IMG_7853
Ford F-150 Lightning Discount Tire Promotions, Road Hazard warranty and lifetime road force balancing / rotations plus local install options available. IMG_7302
Ford F-150 Lightning Discount Tire Promotions, Road Hazard warranty and lifetime road force balancing / rotations plus local install options available. IMG_7311
