Pairing TPMS Sensors For New Wheels / Tires ?
SpaceWhiteF150
Montgomery, Texas
2021 F150
Have any of y’all ordered wheels and tires through custom offsets? If so how did you get the new tpms sensors to communicate with your truck?
Kanuck
Don
Manitoba
2021 Super Cab Carbonized Grey 3.5 EC 302A 6.5 Box
Electrician, Retired
Most tire shops or the dealer can teach the truck the new TPMs. They have to be the correct frequency tho.I think it is 315MHZ. I had to replace the TPMs in my winter tires and rims to match the 21 and the tire shop got the truck to read them.
pkinneb
Paul
Zimmerman MN
2003 & 2018 MX5's, 2021 F150 PB Platinum
NH_Leadfoot
Geoff
NH
2021 F150 XLT 302A
.GOV
I bought a winter set of wheels/tires for my truck a few months ago and went through this in last month when I installed them on the truck. I went to my local Ford dealership and had them order 4 OE Motorcraft TPMS sensors based on my VIN. The dealer told me I would have to bring the truck back once I mounted the 2nd set of wheels to be programmed. I bought one of the $15 gray square/green button TPMS tools on eBay that corresponded with the frequency of the TPMS sensors. The learning procedure took less than a minute and was much easier than I thought it would be. Press the Start button once to "turn on" the ignition, then press the hazard light switch 3x. The gauge cluster then showed 'TPMS learning' or something to that effect. You then take the small little gray tool/green button and starting with the left front, hold it next to the valve stem and hold the green button until the truck's horn honked once. Then proceed to right front, right rear, left rear. Then hop in, start the truck and you're good to go.
pkinneb
Paul
Zimmerman MN
Perfect thanks!! That is what I had found so far as well so nice to know it works. My new wheels and tires are scheduled to arrive 2/10/2022 and will have sensors already installed so I will be picking up one of these! Thanks again.
Agashi25
Arban
Chicago
2015 Mustang GT PP CO
I bought the ford tpms trainer remote on Amazon for my mustang. It was like $17
Dsmenardvt
Dan
Vermont
2022 F150 501A SCrew 6'7" Antimatter PB
Concrete
2nd on the purchase link?
Dsmenardvt
Dan
Vermont
Concrete
Dsmenardvt
Dan
Vermont
Concrete
What I posted, I’m not sure if it works I was just trying to see if it is the same as what was mentioned above
[/QUOTE
Glad you clarified, I didn't catch the different user.
pkinneb
Paul
Zimmerman MN
