F-150 Prius
Adam
Silicon Valley
2021 F-150 Platinum PowerBoost FX-4 6½
Software Algorithms
K02s are great off-road and in snow and all-round, but definitely cost 10% (!) mpg on an F-150 Hybrid.
Keep them at 50 psi cold and when those need to be replaced, get a narrower section width (contact patch is the primary factor in rolling resistance for the same pressure since load, compound and tread pattern are not variables.) A narrower tire will also have better ride quality and better off-road traction (float can always be created with lower tire psi, but contact patch psi is limited by the tire construction dimensions.)
Postman
Ryan
IN
‘21 Raptor, ‘21 Navigator, ‘21 GT500, ‘74 Bronco
Man, that is SHARP! No rubbing issues lock to lock I’m assumimg?
LightningShow
MA
'22 Lariat ER
Product Development
The trip stats posted show 2139 miles. If the tires have only been on for 100 miles then there's no way to see whether it has actually affected the range. Dude needs to reset the trip computer.
lancersrock
Kody
USA - IA
2021 Honda Pilot, 2011 Mustang GT, 2013 fusion se
Field Engineer
I actually reset it at 1650 miles when the tires were added. I'm now at 2400 miles and my average is 1.8kWh on highway and 2.4kWh on city driving.
Whats the road noise like? Good to see that the mileage is still good.
LightningShow
MA
'22 Lariat ER
Product Development
800 miles is a pretty good sample. I'm surprised you aren't seeing lower range but I'm not complaining!
lancersrock
Kody
USA - IA
Field Engineer
Road noise isn't bad...my wife said she hears a little but that's with the radio off. I've also had 35" KO2 mudders on my jeep and that didn't bother me so my opinions could be off but my brother did say he couldn't tell the difference between stock and these when he drove my truck for what that is worth
Thanks! I never thought the road noise was bad in my f150 but recently drove a Camry on a road trip and at 70 it seemed loud, even compared to my fusion with a bad wheel bearing lol.
drummer
Ankeny, IA
2015 Tesla Model S 85D, 22 F-150 Lightning Lariet
Exactly what I was thinking of doing!
T i h o r
Rohit
Toronto
Self Employed
When I turn all the way to either side I get a slight rub but I wanted wider tires so Ill live with it. Getting the 2" ready lift leveling kit done this weekend
Just bumping this to see if you leveled it over the weekend.
Also, and pictures from and angle or even head on? Curious to see if there's a buldge with 305's on the oem rim.
TIA!
