Pro Grill & Lightbar Swap?
jazzmanmonty
Lincoln Corsair
self employeed
Anyone have luck finding parts for this yet?
No luck here. I stopped by parts department at my local dealer and nothing comes up. He says tuck is too new. Which makes me wonder..God forbid one of us gets in a wreck, but what do insurance companies do if say the grill needs to be replaced. Would the consider it totalled if they can't get parts?
Snappy22
NJ
Honda Pilot, Honda CRV
I found my solution for the front grille of my Pro(until an awesome aftermaket one comes out)! I played around with a pic to try to color match the front to the body. The black grille looks sooooo much better painted. IDK why ford didn't do this in the first place! I kinda like the two-tone. but will probably be trickier and mor expensive than just a splash of paint and clear.
Carbonized Grey Metallic look before/after:
Cool idea! And thanks for doing it since I ordered a Carb grey. I think I’d also tint the “lightning bolts” also like another guy did recently in a featured article.
Chimed23
Robert
Buffalo grove, IL
Lightning
Construction
hey all, so I installed the led bar on the pro and here’s what I know so far. The pro grill blank can be simply cut out and grill reused. The light itself has nine wires and communicates with the headlights to turn on/off. There is a wiring harness in place with a blank cap over it ready to go, plug and play no additional wiring needed. I have an appointment at the dealer in a few days to program the function, will update
Ford F-150 Lightning Pro Grill & Lightbar Swap? 9356DFBA-52E5-4DE2-A8E8-1E378D72B954
Ford F-150 Lightning Pro Grill & Lightbar Swap? B414B42A-2CD6-4483-8BF8-3D11F70CDE38
Ford F-150 Lightning Pro Grill & Lightbar Swap? 86ED60C1-D7E7-48C9-9ED5-229BBD1DE836
Ford F-150 Lightning Pro Grill & Lightbar Swap? 1A30E501-A9EA-43D7-873B-A9479AEE1C4F
BennyTheBeaver
Where did you get said light bar? I'm sure a few of us would love to know...
nice59fordf100
russell
austin, texas
2022 lightning pro
manager
Hello all! I was assisting Chimed23 in figuring out the programming needed to make the light bar turn on. It is NOT a simple "12v and ground" ordeal, rather the LDCM's supply 32v and 36v to the light bar depending on circumstances. I have already calculated the As-Built data the needs to change in order to make it work (simply plugging it in does not turn it on). Chimed23 has an appt with a dealer next week with instructions I provided to him to give to the tech in order to turn it on. If it is successful, I will reply here with the instructions for programming.
You can't turn it on with Forscan?
nice59fordf100
russell
austin, texas
2022 lightning pro
manager
So forscan should have a beta version that isnt released yet that works with the BEV ford's, however, I am unsure if Forscan can communicate with the LDCM private can network. Chimed23 is going to the dealer for them to utilize their FDRS to modify the as-built
Going to find out Tuesday at the dealer
In my experience, they usually refuse turn things on and off in an ASBUILT unless adding an approved option, like a trailer brake controller.
BennyTheBeaver
Is the power requirements for the lightbar unique?
Would tapping into one of the matching lights surrounding the headlight be a viable workaround (albeit with a bunch of wire)?
nice59fordf100
russell
austin, texas
2022 lightning pro
manager
Unfortunately not, the LDCM's act as a ballast and drive a higher voltage and can alter that voltage to affect output
Chimed23
Robert
Buffalo grove, IL
Lightning
Construction
Correct, that’s the plan, modify the as built. I confirmed with elec tech that if the system allows they will do it since it’s a factory part and wiring is already in place.
vsansal
Volkan
Arlington,VA
F150 Lightning Pro, Tesla Model Y Performance
Any updates on this? I am also interested to apply this to my pro if you figured it out.
vsansal
Volkan
Arlington,VA
So I am guessing this silince means it didn't work?
