Is this Normal? Mach-E on Sync
Zzebro
Zach
2022 F150 Lightning Lariat
Has anyone else had this issue? Hopped in the truck after work and suddenly the symbol on the top left of the Sync screen is a Mach-E. I still have the same sync version and Pro Power version (and yes, I know it’s an old version. Sore subject).
just wondering if it’s normal or has happened to anyone else.
Ford F-150 Lightning Is this Normal? Mach-E on Sync IMG_6506
Ha, yes this happened to me after an update, I forget which one, it reverted back to the lightning after a short while (maybe after turning off and back on?). There's a UI update you should get at some point and that image goes away.
I'd be more worried about not having the screen update than the Mach-E.
Zzebro
Zach
Well, y
Well, yea that’s my main concern. Wondering if this is linked or maybe a sign that some sort of updating is happening.
Gimme_my_MME
You just got an OTA update. Yours is a bit further behind so this is the same update that caused this to happen for others a few months ago
Zzebro
Zach
good to know! Should I be getting app messages/notification when this sort of thing happens?
Gimme_my_MME
You should.....but that doesn't mean it always happens
Most of them, yes. Both the truck and the FordPass app will notify you. I seem to recall being surprised by this one (referring to whatever updated and changed the image as a bug) and not seeing an update notification. You can always check the update page and it will tell you the most recent (numbered) update. This particular one may have been a download that unintentionally reset the image. I'd expect a bigger update for you coming soon.
