Turn Signal Indicator blinking fast
gbuydos
gbuydos
Central Iowa
F150 Lightening Flash '24
Did you ever try the 12v reset? Mine started giving me a blind spot monitoring system error and fast turn signal indicators on both sides this morning. Still was doing it this evening.
No, the vehicle is always parked outside, and we are in a cold snap. Negative temps. I will wait for the weather to warm a little when I can work outside. The turn signals all work, i double checked. I am guessing its from the Blind Spot monitoring system not working. But i don't drive freeways, so no big deal. It should warm up to the 30s and 40s next week, then I can try.
Gimme_my_MME
So did you try the 12v reset?
Gimme_my_MME
No, unless you know of another way than disconnecting the 12V Neg battery terminal.
No that is what I am referring to. So you did not yet try disconnecting the 12v
ochemaster
2024 Lightning Lariat XR
I unplugged the 12v battery, waited a bit, plugged back in. This fixed my issues, both the blinker going too fast and the blind spot sensor errors. Thanks a bunch for the tip!
