I'm in the same boat... 2.7 and my desire is some improvement in the factory wheels/ tires without a giant mileage penalty.Any 2.7 folks in here? Leaning towards 295/70/18 ... trying to find a tire between 33-34 ish that won’t absolutely kill power and mileage. I hear conflicting opinions as far as gearing and engines.
Installed KO2 305/65/18’s today. No lift yet, on order.
no rubbing or trim required.
67mph at 65 indicated.
I have the same problem of deciding which larger tire that would fit this rim? The stock OEM 18" rim, I read that it's a 7.5 width rim, another person said it's a 8.5 rim width?On my Lariat FX4 the only option I could pick was this wheel.
My tire size is the
Any idea if this wheel will support a larger tire and how much bigger I can go? I am a bit of a tire and wheel idiot so thanks in advance for the help.
BTW...They are going on a 21 PB 6.5bed Antimater Blue Crew FX4.
I may have an answer...I was just going through the 25ish page print-off my dealer provided with all the details of my build. It says ---Front and rear 18 x 7.5 wheels.I have the same problem of deciding which larger tire that would fit this rim? The stock OEM 18" rim, I read that it's a 7.5 width rim, another person said it's a 8.5 rim width?
Anyone that has a new 2021 f150 4 X 4, what width is the stock 275/65R18 AT tires on ? 7.5" or 8.5" rims?
Thank a lot for the information
Thanks that's solid information on the 7.5" width, I know that their stamp the size on the backside of the rim. So what the largest tire that would fit on a 7.5 w - 18" Height rim? 285/70R18 at 33.2 in height? or 295/65R 18 at 33.1" H ... Stock size is 275/65R 18 tires at 32.0 in height.I may have an answer...I was just going through the 25ish page print-off my dealer provided with all the details of my build. It says ---Front and rear 18 x 7.5 wheels.
thanks. another question. i am leaning towards the readylift 2”. i’ve seen some trucks with this appear to have a little bit of a bro lean. would you say your truck is exactly level or does the front appear to be a bit higher than the back now?
Use this site to make sure the tires you consider are ok on the 7.5” rim…… https://tiresize.com/chart/
Chain stores like Discount Tire will not mount tires on wheels outside of these width parameters.
[/QUOT
I stand corrected, 2021 F150 has stock 8.5 rims with 275/65R 18 stock tiresUse this site to make sure the tires you consider are ok on the 7.5” rim…… https://tiresize.com/chart/
Here is what Zyvin said 8.5 stock rims, he correct, look at thisThanks that's solid information on the 7.5" width, I know that their stamp the size on the backside of the rim. So what the largest tire that would fit on a 7.5 w - 18" Height rim? 285/70R18 at 33.2 in height? or 295/65R 18 at 33.1" H ... Stock size is 275/65R 18 tires at 32.0 in height.
Anyone can comment with no lift no rib?
Thank you for the info too!!
That's a different wheel and tire than mine. Mine is a 18 x 7.5 wheel.Here is what Zyvin said 8.5 stock rims, he correct, look at this
https://www.f150gen14.com/forum/threads/stock-wheel-offset-44-mm-size-18x8-5.1017/
Thank you for the correction, my mistake on type of rims. I getting a different rim than stated.That's a different wheel and tire than mine. Mine is a 18 x 7.5 wheel.
