Factory Wheels with Aftermarket Tire Thread
SFD9
Wisconsin
Raptor, 2021 f-150 on order
Self
Installed KO2 305/65/18’s today. No lift yet, on order.
no rubbing or trim required.
67mph at 65 indicated.
Ford F-150 Lightning Factory Wheels with Aftermarket Tire Thread 8A6163E4-64B3-46B4-8A5A-3D21CFAD5B88
Ford F-150 Lightning Factory Wheels with Aftermarket Tire Thread E72B49FA-2E15-4F82-BF0D-0CB3782C03E3
Ford F-150 Lightning Factory Wheels with Aftermarket Tire Thread 47E52758-D2E1-4A6C-B953-40A8FBE89944
Ford F-150 Lightning Factory Wheels with Aftermarket Tire Thread C6765000-03C0-4D6F-A7EE-FEF236C59BC0
flynavy
Midwest
2018 XLT
Pilot
Any 2.7 folks in here? Leaning towards 295/70/18 ... trying to find a tire between 33-34 ish that won’t absolutely kill power and mileage. I hear conflicting opinions as far as gearing and engines.
Cbaka27
Utah
2021 F150 on order
Sales
On my Lariat FX4 the only option I could pick was this wheel.
Ford F-150 Lightning Factory Wheels with Aftermarket Tire Thread 1625162736264
My tire size is the
Ford F-150 Lightning Factory Wheels with Aftermarket Tire Thread 1625162778922
Any idea if this wheel will support a larger tire and how much bigger I can go? I am a bit of a tire and wheel idiot so thanks in advance for the help.
BTW...They are going on a 21 PB 6.5bed Antimater Blue Crew FX4.
85Mustangman
Michael
Toronto, Ontario
2021 XLT Supercab/ 6.5 box, 2.7, 302A, Antimatter
I'm in the same boat... 2.7 and my desire is some improvement in the factory wheels/ tires without a giant mileage penalty.
Not sure what you mean by killing power?... assume you just saying the extra weight of a larger/ heavier tire is a power penalty where the rubber meets the road?
I went with the 20" Chrome like PVD and 275/60 R20 OWL A/T. I understand most of these come from the factory with the Hankooks, and what I've seen on the lots are far from A/T!... pretty much streety tires if you ask me.
Looking for a manly-er set which I can convince the wife I need for a winter set!??
Roger1108
Roger
SF BayArea
1995 F250 Turbo Diesel,2021 F150 Lariat PowerBoost
My tire size is the
I have the same problem of deciding which larger tire that would fit this rim? The stock OEM 18" rim, I read that it's a 7.5 width rim, another person said it's a 8.5 rim width?
Anyone that has a new 2021 f150 4 X 4, what width is the stock 275/65R18 AT tires on ? 7.5" or 8.5" rims?
Thank a lot for the information
Cbaka27
Utah
2021 F150 on order
Sales
I may have an answer...I was just going through the 25ish page print-off my dealer provided with all the details of my build. It says ---Front and rear 18 x 7.5 wheels.
Roger1108
Roger
SF BayArea
Thanks that's solid information on the 7.5" width, I know that their stamp the size on the backside of the rim. So what the largest tire that would fit on a 7.5 w - 18" Height rim? 285/70R18 at 33.2 in height? or 295/65R 18 at 33.1" H ... Stock size is 275/65R 18 tires at 32.0 in height.
Anyone can comment with no lift no rib?
Thank you for the info too!!
Norris McCarty
Norris
San Angelo Texas
21 F150 Lariat 4x4 PB 7.2k FX4 17”Raptor Beadlocks
Own a RV dealership
Use this site to make sure the tires you consider are ok on the 7.5” rim…… https://tiresize.com/chart/
Chain stores like Discount Tire will not mount tires on wheels outside of these width parameters.
Mike505
2021 F150 KR
I think it appears quite level now—— does yours have FX4 package? If not that might give different results
thanks. another question. i am leaning towards the readylift 2”. i’ve seen some trucks with this appear to have a little bit of a bro lean. would you say your truck is exactly level or does the front appear to be a bit higher than the back now?
Roger1108
Roger
SF BayArea
[/QUOT
I stand corrected, 2021 F150 has stock 8.5 rims with 275/65R 18 stock tires
Zyvin was the person that corrected me, here what he showed me. Check it out.
https://www.f150gen14.com/forum/threads/stock-wheel-offset-44-mm-size-18x8-5.1017/
Roger1108
Roger
SF BayArea
Here is what Zyvin said 8.5 stock rims, he correct, look at this
Cbaka27
Utah
2021 F150 on order
Sales
Norris McCarty
Norris
San Angelo Texas
Own a RV dealership
The chrome Lariat(and maybe XLT) wheel is indeed a 18X7.5. The machined aluminum is 8.5 wide.
The 7.5” wheel came on my Lariat, Chrome Pkg, FX4.
Lex_310
Alexis
Wilmington
F150 XLT 5.0 SuperCrew FX4
Anyone else running 275 70 18 without a lift or level on A stock FX4? Thinking about going up just one size without having to level in the meantime.
Roger1108
Roger
SF BayArea
That's a different wheel and tire than mine. Mine is a 18 x 7.5 wheel.
Thank you for the correction, my mistake on type of rims. I getting a different rim than stated.
