2021 F150 5.0L V8 Borla Touring Black Tip Twin-Exit Cat-Back Exhaust Kit 140873BC
Stage3Motorsports
Arizona
2021 F150 STX CrewCab 4x4
I have 1 system in stock for immediate shipment if anyone is interested message me for forum pricing.
Ford F-150 Lightning 2021 F150 5.0L V8 Borla Touring Black Tip Twin-Exit Cat-Back Exhaust Kit 140873BC 1639602491672
2021 F150 Borla Touring Cat-Back Features:
  • Adds a nice exhaust note with low drone for your F150
  • Complete Borla F150 Cat-Back Exhaust system
  • Features both a resonator and rear muffler
  • Uses a combination of 3" and 2.25" diameter tubing
  • High-quality 304 stainless steel construction
  • Twin-side exit tailpipe design
  • Comes with 4" diameter black tips
  • Bolt-on replacement for stock
  • Backed by a Million Mile Warranty
Provides a Deeper, More Noticeable F150 Exhaust Tone without Causing Drone
While the 2021 F150s may be some of the most powerful and capable F150s yet, the pitiful noise that comes out of the stock exhaust certainly doesn't let you know it. The Borla Touring Twin-Exit Cat-Back Exhaust Kit for 2021 F150s gives your clean, mean F150 build both a great sound and a new look all on one single package. The Borla Touring kit was designed from the ground up to provide extremely minimal levels of drone while still giving your 2021 F150 build a deeper and more noticeable exhaust note. Each Touring Kit adds a clean and noticeable rumble to your F150 without giving you a bunch of a drone and rasp at cruising speeds. This version of the F150 Touring Cat-Back features a twin-side exit design with two tips that exit in the factory location which gives your F150 a subtle change in appearance that is sure to get noticed. The 2021 F150 Borla Touring Kit is made out of high-quality materials and features an easy, bolt-on installation in place of the stock cat-back so that you get a hassle-free sound and aesthetic upgrade for your awesome 2021 F150. 304 Stainless Steel Cat-Back System with CNC Mandrel-Bent Tubing and 4" Tips
Borla manufactures each of their 2021 F150 Touring Cat-Backs out of extremely high-quality materials and precisely designs and manufactures each kit for a near-flawless fit on your 2021 F150 build . The Borla Touring Kit features 3" diameter tubing from the mid-pipe connection to the muffler that then splits into two 2.25" tubes after the muffler which gives you an overall increase in exhaust system volume over stock. All of the tubing is precisely CNC mandrel-bent to ensure smooth exhaust outflow with limited restrictions and backpressure. The kit comes with both a forward resonator that helps tamps drone down, as well as larger rearward muffler that generates a louder exhaust note than stock without being too overbearing. The system is made entirely out of 304 stainless steel that's resistant to corrosion and discoloration in nearly any climate or application. The system is topped off with 4" black exhaust tips that exit in the factory location in front of the passenger's side rear tire. The kit comes with hardware, instructions, and Borla's legendary Million Mile Warranty. Each kit is made right here in the USA.
Fitment: 2021 F150 5.0L V8
Wheelbase Fitment: this cat-back will only fit F150s with a 145" wheelbase out of the box. Borla's adapter pipe for 157" wheelbases is here and Borla's adapter pipe for 163" wheelbases is here.
