2022 Scales/Smart Hitch Option 55S
ARegularJoe
Joe
Feb 2 Order: 22 Lariat 500A/3.5 EB/FX4/Max Tow/+
Do any of your folks know exactly what comprised the smart scales option? Are there some sort of sensors added to the body/frame/hitch that measure these points in addition to some SW update to an existing module? I am wondering how hard it would be to retrofit that option to a 501A/3.5 EB/FX4/Max Tow. My Feb 2 order was acknowledged by Ford and my price locked in so I am afraid to even consider now adding that change to the package for fear of having the new MSRPs applied and my order repriced.
SomebodyInGNV
Gainesville, FL
2016 F150 Lariat 500A MaxTow 3.5L EB
I ordered it. It seems to me it would be hard (or very expensive) to retrofit. It also seems like it might not be a good idea to add any after-market suspension parts.
tbinmd
18 KR F150
There's sensors on the suspension. There's some pictures floating around of the sensors that show how they attache to the suspension. In one of the build videos it shows a truck being calibrated by a robot arm pressing down on the bed. Doesn't sound like something you can add after the fact.
780
edmonton
2015 F150
Hmm... I ordered it on my build. Debating a level lift but now I'm wondering if that would screw with the sensors for the scales?
Handle
2015 Mustang
gendibal
M
DMV
Ordered: 2022 F150 Platinum PB
Right. I'm fairly certain that helper springs/bump stops/etc. will not be compatible with smart hitch unless there's a way to recalibrate in the field. And if there are robots involved in initial calibration, that sounds pretty involved...
ARegularJoe
Joe
Jees, with all these worries, it may be better just to glue a bubble level to the inside of the box.... or better yet, power and affix an old iphone in the box to provide input to another smart device providing positional information at all times... . I may be on to something!
SomebodyInGNV
Gainesville, FL
I'm not worried. I have no plans to modify the suspension.
There has to be a way for dealers to calibrate it. What happens if the truck's in a wreck or one of the shock absorbers goes bad? They have to replace parts. I suspect it may involve adding known amounts of weight to the bed. They could do that with water bladders fairly easily. I'm sure there are other methods.
SomebodyInGNV
Gainesville, FL
I’ve got CCD it works great in Drive Modes and overall ride is as designed. It’s very customized to your truck ...
Thinking about this, can an XLT with onboard scales be retrofitted with CCD?
SuperRaptor
Shane
2018 Lariat 502A
That’s a good question. On the higher trucks you have to combine them, I didn’t realize that you could order just the scales.
