eTruckFan
Guest
Selling a like-new 2023 Ford Lightning Lariat Extended Range, Carbonized Grey Metallic. Owned about two months with fewer than 530 miles on the odometer as of this posting. I waited nearly two years after putting in a reservation with Ford but the timing was bad when the truck finally arrived. I have higher priorities now so I've decided to sell. If you don’t already have a Lightning reservation with Ford, you’re looking at 2025 delivery at the earliest. Or you can buy this one, avoid future price hikes and go straight to the front of the line.
This is a really fun truck to drive. The instant power and torque on a full-size truck is an experience like no other. The truck offers a spacious interior and the comfortable seating makes it perfect for hauling you, your family and everybody's gear. Even with the increase in elevation, the Extended Range battery got me from the Bay Area up to the mountains with no stops along the way to charge.
Three additions: all-weather mats, a spray-in bedliner and a RetraxPro XR retractable tonneau truck bed cover ($150, $500 and $2,300). Besides those, this truck is yours to customize.
It has all the 2023 Ford Lightning Lariat Extended Range battery options and more:
*511A package
*Ford Co-Pilot360 Active 2.0
*Tow technology package
*Twin panel moonroof
*20 inch alloy dark gray wheels
*All season tires
*Toff spray-in bedliner
*Ford Pro Charging station (still in the box)
If you are looking at this truck you probably know that it has bi-directional charging capabilities. Meaning you can charge the truck and also use the truck to supply power for your home or anything. It comes with a mobile charger as well as a Ford Pro charger which I did not install. This Pro charger, once installed, can charge the truck at 80 amps and supply power to your home in case of a power outage. It’s like having a big generator for your home, which you can also drive. The battery size on this truck is 131 kWh. If you were to secure a Tesla battery wall system with 131 kWh battery capacity, the cost could be in the range of $100k.
Please serious buyers only. Please send me your name and number and we can schedule a time to look at the truck. Proof of funds or loans prior to meet up if you are serious about buying the truck.
Thanks, Dave
415-484-5418
*511A package
*All season tires
Thanks, Dave
415-484-5418
