Factory Wheels with Aftermarket Tire Thread
rathbunr5
rathbunr5
Bobby
Connecticut
2022 Ford F-150 Lariat Sport (Space White)
Sales Manager at Torrington Ford
Thanks. You had to cut the lugs with those spacers though huh?
[/QUOTE
hell no! If I had to do that I’d never use the spacers
CaptainAmericaRob
Ed
2021 F-150 Lariat FX4 PB
Machine Designer - Ford Motor Co.
Hey Guys, just got done swapping off the 295/70’s for the 35x12.50r18 Ridge Grappler. I am happy to report ZERO rubbing with a RC 2” level with rear block/shock kit.
truck sits Perfect! IMO... exactly how i want mine to sit. great to know the 35's fit with no issues on stock wheels.
I worked in Wheel testing, so I know how durable and well tested OEM wheels are.
rathbunr5
rathbunr5
Bobby
Connecticut
Agreed with everything you said. 1) yes the oem wheels are very durable which is what I need for these northeast winters. That’s why I don’t go with aftermarket wheels.
2) the RC kits with the rear block/shock kits is the best stance in my opinion as well because it lifts the back up an 1” as well so the truck still has a little rake. I don’t like perfectly leveled trucks because when you tow the back end tends to squat lower than the front
CaptainAmericaRob
Ed
More pics of blacked out stock 18inch sport wheels with 295/70/18 nitto ridge grapplers.
looks awesome, how durable has the plasti-dip been? any issues with it chipping or peeling off yet?
Tizzzo
Ed
2021 Lead Foot Gray XLT 5.0 Supercrew 4x4
Veteran
Very durable but I used about 1 can per wheel to make it extra thick. I’ve taken it off-roading and it hasn’t peeled anywhere so far (y)
Tizzzo
Ed
Veteran
Got the raptor take offs installed yesterday, I will take better pictures later today. 315/70/17 BF Goodrich K02 tires on 21 raptor 17inch wheels. No rub at all! Also not sure if it’s because the BFGs are C rated vs the nittos E rated or because there’s more sidewall, but these seem to ride a bit softer than the 295/70/18 ridge grapplers I had on which is an unexpected plus.
Ford F-150 Lightning Factory Wheels with Aftermarket Tire Thread 07509170-F09B-4E45-8978-74C630D760CC
Ford F-150 Lightning Factory Wheels with Aftermarket Tire Thread D79D7354-1157-464E-8443-BB43AD6F7F16
rathbunr5
rathbunr5
Bobby
Connecticut
LOOKS SOOOO GOOD!
Jack Miter
New England
2021 Lariat
Looks great. So what wheels were you coming from... 18" or 20"? No issues with the calipers going down to 17"s? And where did you get the take-offs?
Tizzzo
Ed
Veteran
Coming from stock 18s with 295/70/18 ridge grapplers. Found the take offs on offer up for $1,400 with less than 10 miles on them, basically brand new.
Ford F-150 Lightning Factory Wheels with Aftermarket Tire Thread 22349038-5DD8-4937-B797-87BCF4C0DA3F
RCR001
Just North of the USA
2021 F-150
Might be wrong but i think the raptor 17's will be a problem if u have the Max tow which has bigger brakes. Great looking wheels though!
cscheut
Carl
NJ
21 F150; 16 Expedition; 91 Mustang LX; 72 Maverick
CPA
Went with the Fox (Ford Performance) 2” level and 295/60/20 Nitto Recon Grapplers. Very happy with the setup so far.
Apologies if you already posted them, but do have pictures from the front. I am thinking of the exact same set up. Thank you in advance.
Tizzzo
Ed
Veteran
Thank you! Yes this is correct, if you have the max tow package the rear brakes are bigger and 17 inch wheels won’t fit.
zCyko
Lane
Hammond La
2021 f150 XLT
Could you post some up close pics of your clearance with the wheel turned
