Forscan changes blocking OTA updates?
21PlatPB
Jared
Chilliwack, B.C
2022 Volvo XC60 PHEV, 2021 GT500, 2015 Hellcat
I just wanted to ask if anyone that has made changes to their truck with Forscan is still receiving OTA updates? I used to be notified of updates fairly frequently but feel as though I haven't got one since I changed a few things on the truck, not sure if it's a coincidence or not. I noticed some people mentioning getting a Power Up 1.7 update on Facebook the past few days and my truck just says up to date.
Has anyone else that's changed settings with Forscan been receiving OTA updates?
jperry5835
2021 F-150 Hybrid Platinum
I have never received an update and have not had forscan on it. updates are probably not being rolled out to everyone at once to keep from overloading their system. I would give it more time and see if an update shows up.
21PlatPB
21PlatPB
Jared
Chilliwack, B.C
Yeah, I'm sure they stagger the rollout for sure, I just can't remember if I have gotten any updates since changing some stuff with Forscan. But you're right I'll give it some more time and see how it goes.
tonesto7
Anthony
2021 Lariat 502A | 3.5L EB
IT Admin | Software Developer
FORScan will not interfere with OTA unless changes you made throw permanent DTCs. Which the specific OTA update might not ignore
21PlatPB
21PlatPB
Jared
Chilliwack, B.C
Perfect that's what I was looking for I should be good to go then. All I did was recalibrate tire size, global windows, horn honk disable, and digital temps in the cluster.
tonesto7
Anthony
I personally have modified just about every module and have received 3 OTA updates
Big Dog Daddy
New Jersey
2021 F150 Lariat 5.0 4x4 Ex Cab Antimatter Blue
Hi have you received any over the air updates since this posting?
Big Dog Daddy
New Jersey
I have yeah, seems like forscan changes shouldn’t block the OTA updates.
Thanks, That's great to hear. My over the air updates is all locked up and there are many in the same boat. Automatic update setting toggles are lock and off, apparently some trucks started to down load and failed on installing. Sync version number and rev numbers are disappeared in about SYNC.
Thanks again.
