Jim Lewis
- First Name
- Jim
- Jan 10, 2023
- San Antonio, TX
- Honda Accord 2017; 2023 Lariat ER
- Occupation
- Retired
I've tried searching the forum and asking AI what the following circled connector does, but found no answer. I've had a problem with my frunk hood not closing and not even sounding a warning alarm when either the cab dash, frunk hood, or FordPass frunk open/close buttons were pressed.
See https://www.f150lightningforum.com/...lock-toggles-update-post-95.29258/post-547992
Today, in an uncontrolled experiment, I tried rattling the frunk lift struts and wiggled the wiring connector circled in the picture below, felt it a bit loose, and appeared to seat it with a push and a click. After that, my frunk closed normally. Interesting that there is a (broken) frunk clip connector plug in the top of the plastic that holds the receptacle plug for the loose connector. Perhaps either my long, rough 3400-mile road trip or continually removing and replacing my right frunk cover to trickle charge my 12V battery has more to do with my frunk hood closing problems than the Sync-25.2.1.6.5 update, which I initially blamed for my frunk problems. (I rattle the right frunk cover to get it to pop of the connector lock slots every time I remove it).
and
https://www.f150lightningforum.com/...lock-toggles-update-post-95.29258/post-548075Today, in an uncontrolled experiment, I tried rattling the frunk lift struts and wiggled the wiring connector circled in the picture below, felt it a bit loose, and appeared to seat it with a push and a click. After that, my frunk closed normally. Interesting that there is a (broken) frunk clip connector plug in the top of the plastic that holds the receptacle plug for the loose connector. Perhaps either my long, rough 3400-mile road trip or continually removing and replacing my right frunk cover to trickle charge my 12V battery has more to do with my frunk hood closing problems than the Sync-25.2.1.6.5 update, which I initially blamed for my frunk problems. (I rattle the right frunk cover to get it to pop of the connector lock slots every time I remove it).
