Glare Free Headlights on 2025
DaveInSA
25 Lightning Flash
I went to do this on mine, but some of my options in Forscan didn't match up with the spreadsheet so I put it off. I need to look at it again.
21st Century Truck
Martin
A warning / caution about the "green telltale" on the IPC dashboard: the glare-free headlight function needs to have changes in (as far as I remember from last year) six (6) different modules to work. The IPC white-to-green telltale change is in only one of these six modules. Other modules are the Headlight module, the Column Stalk Controls (SCC) module, the APIM module etc. etc.
Another way to say the same thing: if the IPC code lines are changed and thus the green telltale shows up on the IPC dash while not all the other code lines in all the other affected modules are also changed appropriately, then the user will have the green telltale on the dash and still not have the full glare-free headlight functionality.
AngelFan2002
Rocky Mountains - United States
2025 F150 Lightning-Flash
Revert to your previous configuration and try again. While making the requisite changes have a copy of the spreadsheet open so you can verify the changes you are making make sense. You'll figure it out.
I must have had something off. I reset everything back to stock and started from scratch and now it is working.
digitaldad
ABQ
2023 Lariat ER MaxTow
I have both symbols, but they are not right next to each other like I have seen in most photos and videos.
Yours is just fine.
I just updated my IPC module to 2024 and my glarefree symbols look just like yours now.
