Hood
Ron Roman
Ron
Sarasota Fl
2023 ford lightning lariat
Caretaker of property
Just in case you find the hood does not latch fully.
2 8mm screws can be removed from the hood latch.
Releasing the hood to its full upright position.
Then use a screw driver to reset the latch reattach the horseshoe latch with the 2 8mm screws and push any button to close the hood.
Your welcome
I used to have an issue with it not fully latching, it would mostly close then pop up a little. Cycling it 2-3 times typically resolved it. However, ever since I had the CSP for the frunk done, it's been flawless.
