Lower dash panel removal
Jimk2121
Santa Clarita, CA
2021 XLT F150 Supercrew FX4
Does anyone know if the dash panel bellow the steering wheel just pulls down from the top and is hinged like it was in the older models? I want to add some switches in it adjacent to factory switches and just want to be sure how to access before I started pulling.
Zyvin
SC
2021 F150 Crew, FX4, Lariat
Awesome! Thank you! Do you have the diagram for the panel directly to the left by chance?
That part to the left that has the headlight switches is part of the whole instrument panel. You can pull off the side piece and then pop out the headlight switches etc. if you just need clearance or to see what you are doing.
Ford F-150 Lightning Lower dash panel removal 5BDCDB32-5D4D-4900-84CB-DE7D852B2A16
Zar7926
Ryan
Maine
2021 F150 XLT Supercrew
System Administrator
Zyvin, Where do you get these diagrams?
Zyvin
SC
Think you can post diagrams for the upper dash, instrument main panel?
Is there specific part/section (airbag side, cluster, radio) you are looking for? The upper IP is about 30 pages long.
JerseyGlock
Jimmy
New Jersey
2021 Lariat Powerboost
I like to remove circled areas and wrap them, 2 by the main instrument panel and the top glove box door. Thanks.
Ford F-150 Lightning Lower dash panel removal 1635385922140
sbi
Upstate SC
2021 F-150 5.0 Lariat SCREW Space White
How do you "release the clips"?!
Crater1511
Toronto
Ford F150
Foreman
Hey bud. Can you post the diagram on how to remove the cluster glass? I’m looking to remove and blow out behind the glass with air as there is dust on the cluster and it’s driving me nuts. Is this doable? Is this cluster sealed?
