MEMORIAL DAY SALES | Save on LED Lights, Air Compressors & More
4x4TruckLEDs.com
Gold Sponsor
Adam
Lindenhurst, NY
www.4x4TruckLEDs.com
Drug Dealer of the LED World
Ford F-150 Lightning MEMORIAL DAY SALES | Save on LED Lights, Air Compressors & More memorial-day-2025-top-header
Our MEMORIAL DAY SALES are here! Be sure to use coupon code MD25 to take advantage of the Memorial Day Sales on eligible items. Check out the complete list of sales below. Our sales period is 5/19/2025 - 5/27/2025.
Ford F-150 Lightning MEMORIAL DAY SALES | Save on LED Lights, Air Compressors & More md25-coupon
Be sure to contact us with any questions you may have.
Phone: 866-991-4331
Text: 631-881-4199
Email: Contact Form
Ford F-150 Lightning MEMORIAL DAY SALES | Save on LED Lights, Air Compressors & More md25header-diode-dynamics
SAVE UP TO 15% on Diode Dynamics Lights
Diode Dynamics SS3 Pro/Max Pods & Fog Kits are 15% off. Also Save 15% on Diode Dynamics SL2 Pro LED Bulbs, C1R HitchMount Reverse Kits & Rock Lights (4 Packs, 8 Packs & 12 Packs). Use coupon code MD25 at checkout.​
Ford F-150 Lightning MEMORIAL DAY SALES | Save on LED Lights, Air Compressors & More md25header-onboard-air-compressors
SAVE 15% on Onboard Air Compressor Kits w/KR Off-Road Brackets
If you've been looking for an easy to install compressor for your Bronco, F150, Super Duty, Tacoma or Tundra look no further. Our KR Off-Road Kits are 100% bolt-on and use factory mounting points. Our kits are 15% when you use coupon code MD25. (Sale does not include the new ARB Brushless Air Compressors)​
Ford F-150 Lightning MEMORIAL DAY SALES | Save on LED Lights, Air Compressors & More md25header-bronco-fog-kits
SAVE 15% on Bronco Fog Kits w/KR Off-Road Brackets
Now is a great time to install one of our fog kits on your Bronco. Our fog kits w/KR Off-Road Brackets are 15% off when you use coupon code MD25. We have kits available for the Modular Bumper and the Capable Bumper.​
Ford F-150 Lightning MEMORIAL DAY SALES | Save on LED Lights, Air Compressors & More md25header-raptor-fog-kits
SAVE 15% on F-150 Raptor Fog Kits w/KR Off-Road Brackets
We didn't forget our Gen2 and Gen3 Raptor owners! Buy any of our fog kits w/KR Off-Road brackets and you'll save 15% on the entire kit when you use coupon code MD25.​
Ford F-150 Lightning MEMORIAL DAY SALES | Save on LED Lights, Air Compressors & More md25header-bronco-raptor-lightin
SAVE UP TO 15% on Bronco & Raptor Lighting Kits
We've got some special lighting kits for the Ford F-150 Raptors & Broncos that are on sale! Use coupon code MD25 to save up to 15%.
2021 Ford Bronco
Gen1 (2009-2014) F-150 Raptor
Gen2 (2017-2020) F-150
Gen3 (2021+) F-150
Ford F-150 Lightning MEMORIAL DAY SALES | Save on LED Lights, Air Compressors & More md25header-kr-off-road
SAVE 15% on KR Off-Road Products
KR Off-Road makes some of the best accessories around. Everything KR Off-Road makes is made here in the USA from stainless steel or aluminum, ensuring they'll never rust. They also feature a lifetime warranty. We're taking 15% off all KR Off-Road products during our sales event when you use coupon code MD25.​
Ford F-150 Lightning MEMORIAL DAY SALES | Save on LED Lights, Air Compressors & More md25header-crystalux
SAVE 15% on All CrystaLux Replacement Bulbs & Wiring Harnesses
Need a replacement set of bulbs for your truck? The CrystaLux bulbs will be 15% off during our sale. Just be sure to use coupon code MD25 at checkout. Grab a replacement set of bulbs for your truck for a quick and easy upgrade! We're also taking 15% off all CrystaLux Wiring Harnesses!​
Ford F-150 Lightning MEMORIAL DAY SALES | Save on LED Lights, Air Compressors & More md25header-form-lighting
SAVE 10% on Form Lighting Headlights & Tail Lights
Use coupon code MD25 and you'll save 10% on Form Lighting Headlights & Tail Lights.​
Ford F-150 Lightning MEMORIAL DAY SALES | Save on LED Lights, Air Compressors & More md25header-behind-the-grill-kit
SAVE 15% on F-150 Behind the Grill Lighting Kits
You'll save 15% on our F-150 Behind the Grill Lighting Kits when you use coupon code MD25. This kit fits all 2015+ F150s (Raptors & Non-Raptors) and is a great stealth lighting kit to add to your truck.​
Ford F-150 Lightning MEMORIAL DAY SALES | Save on LED Lights, Air Compressors & More md25header-diode-dynamics-hitchmount
SAVE 15% on Diode Dynamics HitchMount Reverse Kits
If you're looking for a quick and easy way to add a reverse light kit to your truck then the Diode Dynamics HitchMount Reverse Kit is it! It's a quick and easy installatioin and when you use coupon code MD25 you'll save 15%.​
Ford F-150 Lightning MEMORIAL DAY SALES | Save on LED Lights, Air Compressors & More md25header-free-f150-mount-d-switch-2
FREE F-150 Mounting Bracket w/Diode Dynamics D-Switch Purchase
The new Diode Dynamics D-Switch is out and it's one of the best 8-port switch panels on the market. As a special bonus this Memorial Day we're throwing in our KR Off-Road Controller Mounting Bracket FREE when you use coupon code MD25. This mounting bracket fits all 2015+ F-150s and 2017+ Super Dutys. It allows you to easily mount the Diode Dynamics Main Hub in the engine bay for easy access.​
Ford F-150 Lightning MEMORIAL DAY SALES | Save on LED Lights, Air Compressors & More md25header-truxedo-elevat
SAVE $70 on TruXedo Elevate FS Racks
We're taking $70 off the TruXedo Elevate FS Rack. This adjustable rack fits most bed covers with a T-Slot system and is the perfect addition to your truck bed. Use coupon code MD25 at checkout.​
Ford F-150 Lightning MEMORIAL DAY SALES | Save on LED Lights, Air Compressors & More md25header-amp-research
SAVE $200 on Amp Research Powersteps
Use coupon code MD25 at checkout and you'll save $200 on a set of AMP Research Powersteps. These retractable steps/running boards are the "OG" running board and are built to last.​
