Michigan Nokian Hakkapeliita R5 Snow Tires - Lightly Used - Fits OEM Lariat Wheel
MJDore
SE Michigan
2023 Lightning Lariat ER
Finance
I sold my Lightning a couple of weeks ago and only used these Hakkas for one Winter. Before selling, I swapped the original Generals back on so I have these available if anyone is interested in purchasing. You can see from the pics I put about 4,500 miles on them. They're practically new. Paid $1300 new. I'd sell them for $900 or make me a decent offer. They currently show as Out of Stock on Tire Rack. WHEELS NOT INCLUDED.
I'm in Southeast MI and would prefer not to ship but can work it out if you're not within a decent drive of here. Willing to meet you somewhere even if it's a couple hours' drive.
These tires were absolutely terrific. The OEM Generals are complete garbage in the Winter with a truck this heavy. The Hakkas were flawless. I didn't do any real world range testing but I did do a 2,100 mile roundtrip in Florida in Feb with these, in the harsh cold and high winds of Michigan and Ohio, and the range hit was nominal. Still averaged around 1.8 mi/kWh with mostly interstate driving. YMMV, of course, depending on driving conditions. Specs:
275/60R20
116T
Load Range: XL
Ultra Low Rolling Resistance
Ford F-150 Lightning Nokian Hakkapeliita R5 Snow Tires - Lightly Used - Fits OEM Lariat Wheel Nokian invoic
Ford F-150 Lightning Nokian Hakkapeliita R5 Snow Tires - Lightly Used - Fits OEM Lariat Wheel discount tir
Ford F-150 Lightning Nokian Hakkapeliita R5 Snow Tires - Lightly Used - Fits OEM Lariat Wheel hakkas4
Ford F-150 Lightning Nokian Hakkapeliita R5 Snow Tires - Lightly Used - Fits OEM Lariat Wheel hakkas3
Ford F-150 Lightning Nokian Hakkapeliita R5 Snow Tires - Lightly Used - Fits OEM Lariat Wheel hakkas2
Ford F-150 Lightning Nokian Hakkapeliita R5 Snow Tires - Lightly Used - Fits OEM Lariat Wheel hakkas1
Nolander
Scott
2023 F-150 Lightning Lariat Extended
Best snow tire ever.
MJDore
MJDore
SE Michigan
Finance
They sure are. I was just about to re-post now that people are starting to think about the Winter. Shoot me a message, if you’re interested. Happy to take more pics, if you’d like.
Coffee4matt
Matt
Springville, UT
Honda Ridgeline, MBZ GLC300 4Matic, 1968 Pontiac GTO, 2022 Harley Davidson V-Rod
Does the Rotation direction for these tires really matter?
If so, it appears that the passenger-front tire in the photo is mounted on the truck such that it would rotate in the opposite direction of the arrow displayed on the sidewall of the tire...? (except when the vehicle is moving in reverse)
Coffee4matt
Matt
Springville, UT
About to experience my first winter w/ the Lighting in an area w/ deep snow here over the winter in the mountains of northern Utah at 5,200' elevation ...I think snow tires will be a good idea!! Thanks for pointing out this brand for consideration!
21st Century Truck
Martin
Winter tires help with snow but they also help a lot with grip in freezing temperatures, even if there is not a flake of snow in the area.
Their different rubber compound does the trick. All-season tires harden up in freezing temps and lose a lot of grip.
This is BTW why it's not a good idea to "wear" Winter tires above about the low 40s F... their rubber compound is calculated to stay soft when it's freeing so they will wear out in a flash when it gets warm(er).
If You are considering getting Winter tires, a lot of us who use them get steel wheels as the 2d set of wheels... much easier to keep them in shape over hard ice ridges and iced-over curbs, and a steel wheel edge can usually be pounded out if damaged.
Cheapskates back in Boston Massachusetts would be known to alternate Winter and all-season tires on the same sets of wheels... to the rapid detriment of their bead wires getting popped by the shop tire guys who did their tire switching twice a year. If You do get Winter tires, it's better to get the 2d set of wheels too.
