OBDII Programmers
andy
F-150 Lighting Flash
Calling any F-150 Lighting OBDII programmers or experts please ;)
I am in the process of developing a (Raspberry Pi) Pico W application for reading and displaying F-150 Lighting data. Using an ELM327 Bluetooth OBDII adapter, the Pico W sends commands / reads data over Bluetooth, and also acts as a WiFi Access point. Log your phone / tablet onto the SSID and it displays the data in real time as a web page.
From the PIDs lists on this forum I have got most of the data displaying. But some queries for those further ahead:
  1. What do the 'HVB Temperature Range' data items refer to? I can see a value for each of the 4 items, but no sure what it is telling me in plain language terms :crying:
  2. Are there any PIDs giving position e.g. GPS, and altitude?
Any help appreciated...
andy
GPS seems to be as here - yet to see what 'degraded' might imply?
rugedraw
Javier
Miami
Auto Sales
@kennelh May be able to provide some insight on this.
theUNSTABLE
Ryan
github.com
Cyber Engineer
@andyF150Lightning Did you make any progress on this?
Do you have any vehicle profiles you could share?
I'm about to start doing this, and I've thought about it for a while.
I recently discovered this (https://www.crowdsupply.com/meatpi-electronics/wican-pro#products) and have ordered one.
I'm tired of the cat and mouse game with the FordAPI (fordpass-ha), the App being slow and not having features I want.
I've decided to attempt to make my own app-like experience using Home Assistant.
andy
@theUNSTABLE Did you make any progress on this?
Yes - but juggling about 14 projects at once :sadface:
In essence I have working the F150 Lighting > OBDII Port > Bluetooth adapter > (Bluetooth) > Raspberry Pi Pico W (+software) > (WiFi) > Tablet / Phone / PC browser.
I am not sure there is anything 'new' I can share - I am using the Module and parameter codes linked on the spreadsheets form this forum. Currently it displays data in real time, and I select what data is obtained and how often.
The GPS linked above works, just it is only given to (I think) 0.01 degrees i.e. about a mile. Fine if you are looking for generic distance to go v Battery, not if you want to find an address on a street!
Whilst I will likely be happy to share the software, it will be Pico W specific - that said they are only ~$5, need 1 USB cable and the software file is easily flashed across from a PC.
Next step is "gauges" rather than just digital data which I have got working generically, but not yet tied into F-150 parameters.
theUNSTABLE
Ryan
github.com
Cyber Engineer
andy
@theUNSTABLE
> Since you're using a Pi, I'm assuming you looked into https://docs.autopi.io/
I hadn't seen that. However, the Raspberry Pi 3/4/5 is very different to the Pi Pico - the former run the Linux OS and are mini computers in the own right. The Pic Pico is a microcontroller without even an OS.
mr.Magoo
2022 Lariat ER, AMB
Degraded as in accurate within a county or two.
I ended up using a mpcie lte/gps adapter since i wanted data as well, for the pico you probably use a normal USB dongle.
