jgb22222
Thought I would share this if it helps anyone else. I have a 2021 F150 PB in Lariat Sport that came from the factory w the Hankook 275/60/20's.
I will be replacing them w Toyo AT 3s in LT 275/65/20 (34s) and adding a Fox 2.0 suspension lift. I have been trying to figure out the PSI to run on the Toyo's. I emailed them to ask proper PSI and they responded within a few hours with the below. I was super impressed w the speed on the response. Thought I would share if this helps someone.
I may run it a little below 48PSI but good to know what they recommend to handle the max load
Based off the information provided, recommended air pressure should be 48psi.
Original Tire: 275/60R20 115...35psi (2590 per tire)
New Tire: LT275/65R20 126...48psi (2598 per tire)
Toyo Tires U.S.A. Corp.
| 4:06 PM (3 hours ago) | |||
