Running 17” Winter Tires on 18” Factory vehicle
Icbmredrat
Wade
Toronto
F-150 XLT 4x4 Supercrew
Hello.
302A XLT here with stock 18” wheels. Looking to see if it is possible to run 17” winter tires to save a bit of money. Any negative mechanical effects?
Thanks
My 2ND Ford
Ny
2021 f-150 Platinum, 2014 BMW R1200RT
Hello.
Thanks
The 17 inch wheels may not clear the brake calipers if you have the max trailer tow as I understand the rear rotors are larger diameter.
sempifi99
Indiana
2021 F150 XL Powerboost FX4
Are you talking about 17" rims or stretching a 17" tire onto your 18" rim?
Icbmredrat
Wade
Toronto
I would assume if I don’t have that optional package, it would clear?
Icbmredrat
Wade
Toronto
No. Some trims like XL and even the 300A/301A comes with stock 17” wheels / tires. I want to run steel 17” rims (black / grey ones) with 17” winter tires. I was just wondering if it will trip any sensors or cause miscalculations in terms of mileage.
Thanks
AgieF150
Rakesh
CT
21 & 22F150 limited, 21 Ram 1500 limited EcoDiesel
Thanks
i am running 17” raptor rims on my 22 limited, so far no problem. I don’t see a reason why a sensor will throw a problem
My 2ND Ford
Ny
Thanks
As long as the rolling diameter of the tires you wish to mount is the same or close enough to your OEM tires, then your speedo and everything associated with it will be fine.
My 2ND Ford
Ny
Its always a good idea to try before you buy, just in case. However, when buying aftermarket its not always possible. In this case, they probably would fit.
Icbmredrat
Wade
Toronto
Thank you all for your input.
sempifi99
Indiana
Thanks
Sorry for the late reply, if you are talking about the steel OEM ones it will not be a problem. For aftermarkets just stick close to OEM specs and you should be fine as long as you don't have the larger sized break calipers with the max tow package.
If you are looking to purchase, ford also has an 18" steel rim in black that in my opinion look a lot better than the 17" gray ones the XL comes with.
For speedometer accuracy, I don't think you will find an exact match but as long as your close, wint in a couple percent it should not matter.
tiresize.com is a good website to reference if you have not came across that already.
