Steering Wheel Buttons not Working
Hamlet
Kevin
Winnipeg, Canada
2021 F150 Lariat 502A Sport, 2014 Chevy Camaro SS
Hoping someone can help me with a possible FORScan problem/solution. I was changing some of the simple settings via FORScan, like double honk on exit, bambi mode, power window pressure off (I have rain guards installed) and for some reason all the buttons on my steering wheel no longer work! I never adjusted anything on the steering wheel and returned everything back to normal but the steering wheel buttons still do not work.
Hoping to avoid a trip to the dealer if anyone can help.
tonesto7
Anthony
2021 Lariat 502A | 3.5L EB
IT Admin | Software Developer
Certain IPC changes have done this to me. I can’t remember which ones.
Restore the factory IPC asbuilt and redo your changes 1 by 1
Hamlet
Hamlet
Kevin
Winnipeg, Canada
I restored the SCCM module to factory built settings and that fixed it. Weird but maybe someone else will benefit from my frustrations.
jefrank
Jeff
Fenton, Michigan
2022 Ford F-150 Lightning Lariat, 2004 BMW 330Ci
Yes, thank you. Had the same problem after trying to enable adaptive headlights. Restoring SCCM fixed it, thankfully
