Wisconsin Sunrun Inverter wanted
edlettner
Ed
Fountain city wisconsin
Lightning lariat
Looking to buy ford/Sunrun Inverter to increase capability of my 4kW home integration system. Ideally want an E10, but consider E8 or E6.
tearitupsports
Russell
Cypress, TX
The only thing that the rating makes a difference on is the on-grid solar output capability.
The inverter can also be AC coupled to solar (I did so with my existing SolarEdge inverter). It might be a lot better, and lower cost just to get a separate solar inverter which you would tie into your critical loads panel. In an off-grid scenario, the delta inverter will still signal the other inverter to turn off if the truck is full on battery.
