TCU update taking many many hours
wingfiry
Ryan
Cleveland, TN
2023 Lightning Lariat ER
So...
I got a Mongoose cable and got a 2 day license for FDRS and decided to do some updates. I did the BCM and APIM updates no issues. Then I started the TCU (Telematics Control Unit) update. formatted a 32G USB drive to exfat, FDRS loaded the files, plugged it in and got the expected "Software Updating... Update is in progress. Do not remove the USB drive."
It's now been just over 40 hrs.. Is this normal to update the TCU? Ideas/Suggestions? I'm a bit stressed at this point.
Thanks in advance.
rugedraw
Javier
Miami
Auto Sales
So...
Thanks in advance.
It is not normal. I this point, I would pull out the USB and do a network scan with FDRS to see if the update is still showing there or not. In FDRS, when it shows you the message below, click yes. Then perform another network scan.
USB Software Update Process: 1 - Remove the USB memory device and insert into the vehicle USB slot. 2 - A SYNC touchscreen pop-up should appear within a few minutes that displays "Do not remove USB" (Do NOT remove the USB device until instructed to do so). 3 - To complete software installation, when the SYNC touchscreen displays “Restart Required" turn the ignition OFF and wait 10 minutes. 4 - After waiting 10 minutes in Step 3, turn the ignition to Key On Engine Running (KOER) and wait until the SYNC touchscreen displays "Update Successful". This may take an additional 5 minutes. 5 - Answer the question below to complete the process. Note: Unless there was an explicit Error message displayed select Yes even if nothing was displayed or you are not sure. Did the update install successfully?
wingfiry
Ryan
Cleveland, TN
unfortunately, my FDRS license expired and they (FDRS) are apparently having an outage and I cannot get a new license currently. :rolleyes:
rugedraw
Javier
Miami
Auto Sales
Oh. Yea, tough spot. Thing is, there have been so many GWM released, that even if that one you did went through, there could be another that pops up right after it in FDRS. I would wait a day or however long it takes for Ford to get their FDRS back up and get another license to finish what you started and hopefully you don't get any errors if the GWM is still there when you try it.
wingfiry
Ryan
Cleveland, TN
I removed the USB, shut down the truck and started it back up and everything seems normal. I'll wait a few days and try again later. Thanks!!
rugedraw
Javier
Miami
Auto Sales
In that case, the update most likely went through.
