California WTB: 1 Kicker 3.5 CS speaker
Thaitanium415
Ben S.
2024 Lariat ER
Looking to replace all my speakers with kicker and I’m looking for one 3.5 speaker.
They only sell it on pairs…I only need 1.
Let me know if you have one available.
Ford F-150 Lightning WTB: 1 Kicker 3.5 CS speaker IMG_3695
sstevetx
Thaitanium415
Ben S.
2024 Lariat ER
sstevetx
It was not plug and play and you will have to clip the wires unless you can find something to match the factory plug. This is common for any center you pick. You then can either solder directly to the speaker terminals or add on some quick connect speaker terminal connectors.
The speaker holes don't line up with the Dayton and the factory mount holes. I initially got some wood screws and screwed into the soft plastic around the mount holes. That worked fine, but I decided to overcomplicate it and 3d printed a mount. The mount added thickness and I had to modify the dash cover to accommodate the height. If you go with this speaker, I just suggest screwing into the plastic. I have a post about my speaker setup in the link below. I also have pictures including the center in the post just below it.
https://www.f150lightningforum.com/forum/threads/low-medium-cost-audio-upgrade.17802/post-366448
