4x4TruckLEDs.com
Gold Sponsor
Adam
Lindenhurst, NY
www.4x4TruckLEDs.com
Drug Dealer of the LED World
Hey all. Wanted to share with you this new truck bed system we have available in our stores.
Tmat’s truck bed mat is the ultimate in truck bed organization. Cargo blockers plug into the mat to divide your truck bed into unique compartments around your tools and equipment. By installing Tmat between the wheel wells, the mat can slide across your truck bed and onto your tailgate for easier access to cargo. Tmat can also be customized to install around wheel wells, onto drawer systems, bed slides, or even a sheet of OSB with rollers.
Available from us here: https://www.4x4truckleds.com/truck-accessories/tmat-cargo-system/
Here are some shots of the system installed in our demo truck. I'm a surf fisherman so I have my tackle box, portable shower/rinse system and my fridge in the back.
Ford F-150 Lightning Truck Bed Organization System (Tmat) Photo Sep 03 2024, 3 07 40 PM
Ford F-150 Lightning Truck Bed Organization System (Tmat) Photo Sep 03 2024, 3 07 47 PM
Ford F-150 Lightning Truck Bed Organization System (Tmat) Photo Sep 03 2024, 3 07 56 PM
Ford F-150 Lightning Truck Bed Organization System (Tmat) Photo Sep 03 2024, 3 08 52 PM
Pegboard for the truck bed. I dig it.
BlakeGJ
Blake
Chandler, AZ
2023 XLT ER
Do a custom cut one for the frunk and you might get me. I don't think that plastic will hold up well to the AZ sun with no garage.
These are too expensive to leave in an uncovered bed unattended.
I have one under a rolling bed cover.
For the trunk I use Kallax fabric boxes from Ikea. They work well and can be folded up when not in use.
Frogzwart
Lightning
Tech
I just installed bed slide and it works great with the F150 no drill mounts.
dm5point0
Atlanta, GA
2025 Ford Lightning Lariat
UPS
I was looking at getting this set up. Did you have to modify anything? Their website says the no drill is only good for up to 2019 trucks.
4x4TruckLEDs.com
4x4TruckLEDs.com
Gold Sponsor
Adam
Lindenhurst, NY
ZERO modifications. Fits EVERY TRUCK on the planet without modifications. As it's as 12x12 snap in tile system. Similar to those raised floor systems you find from Racedeck. The 12x12 tiles just click together. You also get 12x2 tiles in the kit so that you can make it fit whatever you want.
Just order it based on the size of your truck bed. We have them for All size beds. Just check out the product listing and you'll see all the different size beds listed to pick from. A 2019 Shortbed is 5'7" so you'd pick the Short Bed (5'6" to 5'9") from the drop down.
https://www.4x4truckleds.com/tmat-truck-bed-organizer-system/
dm5point0
Atlanta, GA
UPS
Sorry...I actually already have the Tmat system (and I love it). I was actually talking about the Bed Slide and the No Drill mounts.
4x4TruckLEDs.com
4x4TruckLEDs.com
Gold Sponsor
Adam
Lindenhurst, NY
I mean yeah you can make it work but bed slides REALLY should be drilled in. The reason is that when that slide goes past your tailgate and has weight on it, it's going to want to lift UP. And it could lift the Tmat panel up. I don't recommend it unless you're just looking for something to slide out light cargo.
dm5point0
Atlanta, GA
UPS
Their no drill mount does mount securely...it uses the factory screws that hold the bed to the frame. You just don't have to drill NEW holes :)
4x4TruckLEDs.com
4x4TruckLEDs.com
Gold Sponsor
Adam
Lindenhurst, NY
Yeah. I thought you wanted to mount it to the tmat itself lol.
But yeah if you're going to use a slide and go through the tmat you probably just need to drill a hole through the tmats that cover the bolt location is all.
dm5point0
Atlanta, GA
UPS
I was planning on putting the Tmat on the Bed Slide...best of both :cool:
K6CCC
Glendora, Calif.
Just want to confirm one thing about the Tmat. As I understand it, the Tmat is just sitting on the bed, not attached to it. So it can't be used to hold something down - only to keep something from moving sideways. Also would likely not keep something that is top heavy from tipping over. For example once in a while I load my 30 gallon 5 HP air compressor into the truck. It's quite top heavy.
With that said, the Tmat system is very cool, and I may install it in my Lightning.
4x4TruckLEDs.com
4x4TruckLEDs.com
Gold Sponsor
Adam
Lindenhurst, NY
Correct it's not going to hold a fridge right side up but a bucket... sure.
The blockers are only about 6" high or so so it's designed to stop stuff from sliding around. You could load things into a crate and the crate won't slide around as it's wider and won't fall over.
For a propane tank i'd put it in a crate and then block the crate in. That'll stop it from falling over from it's height.
K6CCC
Glendora, Calif.
Thanks for the confirmation. Of course for tall stuff, the truck has a bunch of tie down points that cargo straps can attach to, so it's not a big problem.
