F-150 Powerboost tires wearing fast
Stang66
Denver
F-150
I have a F-150 Lariat Powerboost, and it is wearing the outside tread on the front tires. Bought it new and by 5,000 miles the outsides were worn down. Had the alignment checked and everything was fine. Rotated the tires, and only 2,000 miles on them and same thing. The outsides are wearing again. Had the alignment again, Ford says it’s all ok. At this rate going to have to get new tires at 10,000 miles. Anyone else having the same issues?
catfishkid1986
Lee
Lexington, ky
1987 F150 Lariat, 2005 F150 XL, 2021 F150 PB Laria
Material Handler
Got a picture of the tread. It would help understand. If the tread in the middle of the tire is not wearing, and the outsides both are, thats typically under inflation issues. If only 1 outside edge, then it would point to a camber issue.
Ford F-150 Lightning F-150 Powerboost tires wearing fast 1633055385505
Oxford_Powerboost
Austin
Northern Virginia
2021 F-150 Lariat Powerboost
What tire pressure are you running?
Liquid-Todd_AZ
Todd
Arizona
Acura
Sales
I’m hoping my powerboost tires wear out quickly so I can justify my new rims/tires sooner rather than later. Which wheel and tire combo do you have? I have the standard latiat 18” and the Goodyear wranglers are absolute garbage!
Stang66
Denver
F-150
The wear pattern is like what is shown in the picture for Toe. It’s wearing the outside edge only, and only on the front. I’ll have to get a picture of it in the morning.
Stang66
Denver
F-150
Ford F-150 Lightning F-150 Powerboost tires wearing fast 5B734AE8-7DA7-4BA5-A970-E4E15A9642B8
Ford F-150 Lightning F-150 Powerboost tires wearing fast E0F10C15-C0FD-422E-88A8-E2DE5B98B902
Ford F-150 Lightning F-150 Powerboost tires wearing fast 3EDDACA4-988D-499C-A437-2B4E915933D0
Stang66
Denver
F-150
I have the 18’’ Dynapro AT2 tires, not the Goodyear.
RedTXV
2021 SQ Limited
FWIW, I have over 15 F-150’s in my fleet at work, and they ALL do this. Years range from 2012-2020 and is usually noticed between 5-7K miles. Very annoying to be honest.
DGretka
MI
2010 RKP
Ford F-150 Lightning F-150 Powerboost tires wearing fast Screenshot (24)
I don't know if this will help. the fault prob isn't with the tire.
Stang66
Denver
F-150
Update: I finally got it into the dealership, and they told me the alignment was spot on. The issue is when people are in the truck, which is always the case while driving, the alignment can then get “out of alignment”. I kid you not, this is what I am being told. They want me to come in and sit in the truck while they redo the alignment.
catfishkid1986
Lee
Lexington, ky
Material Handler
Having some auto ship training, I can see some truth to this, especially with the front tires. As payload increases, squat changes, which could change camber changes. But I don't think it should be that sensitive to just one person throwing it off.
Theres a few places local to me that do free alignment checks. May be good to look for one of those for a second opinion check. There are alot of different types of alignment machines, and some connections to the tire don't give as accurate of readings, IMO.
jonjon83
Jon
2021 F150 Lariat Hybrid
Partner
I’m having the exact same issue. I have 2021 Lariat Hybrid with 20” rims and those same Hankooks. Only 8000 miles. Tons of wear on outside.
