2021 F-150 Kicker subwoofer VLM3Z-18808-A install
Jeffgmc
Washington
2021 xlt
I recently got a good deal on the Ford accessories Kicker VLM3Z-18808-A subwoofer for my 2021 F-150 and I’m having trouble with the poor instructions. The instructions have you hooking up 3 wires to the head unit. I know I have to take the center speaker out of the dash and the panel that it is mounted to and remove 4 bolts for a bracket that holds down the head unit but I’m not sure what else I need to remove to get to the plug they’re talking about in the instructions. I have installed the unit itself on the back wall and ran the wires up to the kick panel and ran the wires under the hood just need help with the 3 wires hook up on the head unit. Thanks, Jeff
Ford F-150 Lightning 2021 F-150 Kicker subwoofer VLM3Z-18808-A install 4DA5999F-FD00-4F8B-8EC3-D1B6B1515EBC
Jesse-Infotainment
2024 F150 Lightning Platinum
Location 11 – White Wire Location
22 – Black Wire Location
23 – Purple Wire
Goes to the GREY connector of the ACM. When you remove the panel in the center of the dash tht module there is the ACM.
Jeffgmc
Washington
2021 xlt
23 – Purple Wire
So i don’t have to remo
23 – Purple Wire
Thanks. It’s says remove 4 bolts pictured and there are 2 securing the bottom of the PCM not picture? Does the whole screen have to come off? Or does the module come out? Or just unplug the connector from the back but it’s pretty tight behind the module.
Ford F-150 Lightning 2021 F-150 Kicker subwoofer VLM3Z-18808-A install 07818D72-F7B2-48B2-B1DD-9BC39800212D
Jesse-Infotainment
No the acm will come out with the 7mm from the top. You do not need to remove the screen you do need to remove the screen surround
Jeffgmc
Washington
2021 xlt
it looked like there were more than 2 more screws besides the 4 on that hold down bracket.
Graygoose2021
Central US!
2021 F150
Sales
still need help?
Or get it figured out?
Jeffgmc
Washington
2021 xlt
still need help?
Still trying to figure out what I need to remove to get to the plug that I need to stick the 3 wires in. I have the instructions but they are about as clear as mud. Thanks.
Graygoose2021
Central US!
2021 F150
Sales
Call 1-800-256-0808 and ask for Technical. They may be able to assist.
Jeffgmc
Washington
2021 xlt
I just called them and they said they didn’t know what I have to remove to get to the plug that I need to install the 3 wires in to.
Graygoose2021
Central US!
2021 F150
Sales
dang, sorry!
Jesse-Infotainment
You can get to the plug right? You mean you can’t insert them. There is a locking plate on the front of the connector you have to slide to be able to push the pins in. I’ll try to take pics Tomorrow at the office
Jeffgmc
Washington
2021 xlt
Thanks. Any help would be appreciated
I see a plug or 2 from the opening on top of the dash on the drivers side back of the (metal box) head unit behind the 12” screen.
This really sucks when the manufacturer tells you they don’t know what I need to remove to get to the plug. They told me Ford was the one that did the instructions.
Jesse-Infotainment
That metal box is what you want to access. That is the ACM. THat has two plugs on it. Black and grey. You want the grey plug. Once its unplugged that is when you insert the pins after the pin lock is pulled out to allow a pin to be inserted. That metal box can come out through the top. that is how they say to remove it in the workshop manual
Jeffgmc
Washington
2021 xlt
Do you know how many bolts hold it down? Thanks again
Jesse-Infotainment
4 on the top that hold a bracket and 4 on the bottom that you will need an extension tpo access and maybe a magnetic socket or telescoping magnet.
