jcaspar
Sacramento CA
2021 F-150 4x4
That sounds right. The laptop I am using is a Core 2 Duo 1.8GHz with 2 gb ram running Vista Home
ENG430
Ahmad
Kuwait
2021 F150 Lariat 502A
You have a JOB 2 truck. You should have all cams in motion. Also should have cargo cam in the side stack. Plus full screen cargo cam .. I am going to look at your truck history.
Edit. You have the newest IPMA.. You have the correct APIM version you should of had all cams no changes. BUT it looks like you have made some changes.? You cant go by that sheet it is for JOb 1 trucks.
You need to go to 706-04-01 XXXX-X8XX-XXXX
I saw you are in Kuwait... the truck is an actual Kuwait build.. They disabled a lot of the features for that build. You can still try the 04-01 change it will set it to NA and possibly make cams in motion. I do not know if there would be any other impact.
Unfortunately I tried it. No 360 cams on motion.
Many thanks my friend.
I only change the double honk, Bambi mode, Auto start stop, Global windows and seat belt reminder.
I don't remember I change anything else.
THEREED
New England
2021 F150
Ford F-150 Lightning 2021+ F-150 FORScan List / Database / Spreadsheet ? 1646623255995
I am a ForScan newbie who has had success with most of my changes but I did not research the enable camera in motion closely and made the above updates. I have an XLT 302a WITHOUT 360 cameras so making the changes above gave me new menus camera view menus but they obviously don't work and the changes make the hard button above the screen no longer work. My camera works when I go into reverse but the button no longer works even when stopped.
I made the mistake of not backing up my files.... can someone provide me with the original as-built values for the 3 modules above? 2021 XLT 302A without 360 cams
much appreciated
ENG430
Ahmad
Kuwait
much appreciated
https://www.motorcraftservice.com/AsBuilt
Just write your vin number you will get your original as built files.
Jesse-Infotainment
2024 F150 Lightning Platinum
Not for 21. When you change it changes online. These trucks self report. The only module that may not is the BCM all others do. Some of the other vehicles will also with sync 3 if they are on Wi-Fi or are connected.
ENG430
Ahmad
Kuwait
Because I don't have wifi in my lariat 502a.
as uou said alot of features disabled because it is Kuwait build.
Untill now I don't have 360 cams on speed. Only Bed, Hitch an Rear cam on speed. ;(
Keshka
Keshka
Summerville, Oregon
Really? Apparently you have not seen my property.
retired Army major
Ford F-150 Lightning 2021+ F-150 FORScan List / Database / Spreadsheet ? 1646889716604
Sounds like Ford was listening and made it possible to save your vehicle modes (steering, suspension, exhaust, auto on/off) for the 2022MY. I believe that is the only major addition to the 2022 over the 2021. This feature fixes an annoyance in the 21's because the modes had to be set every time you started your Raptor.
Ford added a Raptor button to the steering wheel that opens a new menu on the dash (MyMode Settings).
Looks like a great mod for Forscan hacks to tackle for the 2021 Raptors!
Briansk12
Houston
2021 F-150 PowerBoost
So I got Power-up 2.5.1 yesterday. I now have camera in motion for Rear Cam, Bed Cam, and Hitch cam all in full screen. I also have the ability to see the bed cam in the side screen. These did not work previously. Before 2.5.1 I could get camera in motion for the hitch and bed cam with the 360 view. That is gone now. Mine in a Job 1 truck built in May 2021. Pushing the video button turns the camera on and then you can select which of the 3 you want to view. Are the 3 full screen views what Job 2 trucks have had all along? if so looks like us Job 1 guys are going to be brought up to date.
93dpscoupe
Bruceville, Tx
01 GMC 1500, 93 Mustang LX, 12 Mustang GT
Product Development @ LMR.com
Man, that would be nice to adapt to the regular F150 as well! Part # for the raptor steering wheel is ML3Z-3600-AB. I'd volunteer as tribute, but I probably wont have my truck until August.
daemonic3
Terry
Sacramento, CA
2017 F150 3.5EB
Interesting! Did you have the Forscan hacks before the update or did the update just fully enable everything for you?
I'm also interested in the default Job2 behavior. I enabled the in motion for my Job1 and I do love the bed cam + small 360 card view, so not sure how I'd feel about losing the 360 card. And you said the bed cam card works now? Because that would also be fantastic so I can check on my dogs without a button press.
Briansk12
Houston
I had the Forscan settings already in there. I added the side screen after I saw that camera views were working to see if it would work also.
Platinum Peasant
West Sacramento
This is literally the best message I have read in my entire F150 ownership. I am dying for some updates ???
Ruffiano99
Joe
NY
2021 f150
Has anyone figured out how to deactivate the Active Air Dam feature in Forscan so you dont end up with a bunch of DTCs. Im disconnecting and getting rid of mine, ive had enough of it getting stuck.
jperry5835
2021 F-150 Hybrid Platinum
This is good news, maybe now they will finally start getting Blue Cruise out to us Job 1 people,
