35/12.5/17 (315/70/17) -12mm offset on 2.25” level fit?
fxxkintallguy
Kyle
Los Angeles, CA
www.instagram.com
2021 F-150 XLT FX4 5.0L 302A 5.5 SB
I’m looking through the threads here and noticing most people running slightly smaller setups with positive offset. I’m looking to go wider, but I’m concerned about clearing the crash bar. Does anyone here have a wider setup similar to the title description that can confirm fit with some trimming of then air dam?
I plan to remove the active air dam completely and leave about 1inch of the fixed dam.
I’ll be getting those Amazon flares as well (also if anyone has flare suggestions I would appreciate it!)
Whoskyle
Kyle
AZ
2021 F-150 XLT
I’m running 2” level with 295/70/18 6MM offset and have slight rubbing at full lock
9663mu
Abe
Agoura Hills , Ca
2022 Iconic F150
I did 2in spacer on 295/70/18 fuel wheels positive 20 offset and zero rub or cutting. However on full droop I scrape control arm on coil. Will be changing to bilstiens soon.
dm5point0
Atlanta, GA
2025 Ford Lightning Lariat
UPS
I have 20x9 -12mm on a 2.5" level with 305/55/20 Nitto RGs and I only rub at full lock in reverse. I also have the Air Design Fender flares (they are Ford approved accessories).
Ford F-150 Lightning 35/12.5/17 (315/70/17) -12mm offset on 2.25” level fit? PXL_20220319_220840731
fxxkintallguy
fxxkintallguy
Kyle
Los Angeles, CA
www.instagram.com
This is awesome news. I was thinking maybe 315 was a little too passionate without a lift or suspension swap. Where do you rub?
