Anyone running 20x10 wheels on Lightning?
joesrepsol
Joe
Rocklin, CA
2022 Ford Lightning Lariat
Solutions Engineer
I see a bunch of 2021/2022 F150's on 20x10 with level kits... as long as the tires are too large. Thinking of a 295/60/20 on a 20x10 (-18 et) with 2" level kit on the Lightning. Any ideas if that will fit? rub? Potential fixes if that were an issue?
Not finding the wheels I want in a 20x9 (0mm et) but it is available in a 20x10 (-18 et).
Thanks!
Rob G
Rob
Monmouth County NJ
EQS580, Model X, Cybertruck, Hummer SUT
Is 20x9, 0 offset factory dimensions for a Lariat?
VTbuckeye
Vermont
joesrepsol
Joe
Rocklin, CA
Solutions Engineer
Found this truck on eBay (someone selling). Running 22x10 Fuel Rebel wheels (-12 offset) and 285/55/20 recon grapplers. I think I’m going this route. Love the look of 22s.
Ford F-150 Lightning Anyone running 20x10 wheels on Lightning? BD2FE6AF-4244-4A40-9EFC-AC1519580552
Ford F-150 Lightning Anyone running 20x10 wheels on Lightning? 59FE62D8-7A66-416E-8BCA-DDFA5B41F03C
Ford F-150 Lightning Anyone running 20x10 wheels on Lightning? 1F7B6D15-989B-4EAC-8CCB-AB2337B86332
Ford F-150 Lightning Anyone running 20x10 wheels on Lightning? 595F3484-68E7-42C8-9093-1F995F7128D4
joesrepsol
Joe
Rocklin, CA
Solutions Engineer
This is also a 3 inch front level
Rob G
Rob
Monmouth County NJ
3” seems a bit much to me. It’s starting to get a bit if that Carolina squat look to me.
20x9 44 offset if I remember correctly.
I thought I had read that somewhere but wasn't sure.
joesrepsol
Joe
Rocklin, CA
Solutions Engineer
Personally I can’t stand the front end higher than the rear. So I completely agree. 2” level for me.
Still gonna remove/cut those crash bars to make room for the 34” tires and offset of 10” wheels. I love the look. Raptor didn’t have crash bars, so I won’t miss them :)
sotek2345
Engineering Manager
Not a fan of off road (A/T) tires on such big wheels. Thin tires like that provide improved on road handling by reducing sidewall flex, but make the ride harsher and off road performance worse. For off road you want the smallest wheel you can fit so you have the most rubber to improve traction on a loose surface and to soak up bumps better. Mixing them like this just gets you worse on road performance (less grip and all season or performance tires) and worse off road performance (less flex and more risk of damage to the tire)!
