Your Mileage May Vary
sotek2345
Engineering Manager
I'm also upstate NY. I'm assuming the MY22 XLT SR will get about 120 miles of highway driving in the winter at 80% charge. 1.5m/kwh x 98 x .8 = 118 miles
Seems about right, you might get a little more, but good to plan conservatively.
It is a bit counterintuitive for EVs, but winter range reduction is less the faster you drive since the heater is a constant draw and going faster means the kW used for heat is less for each mile. Air resistance is still a thing and important to consider, but we found we had more range in winter on the highway than going slow around town.
Reactions: MBM
FordLightningMan
Upstate New York
F150
My average daily drive is around 90 miles, so I should be fine. If I feel any anxiety, I'll likely just charge to 90% in winter and 80% all other times. This gets me another 10+ miles. I assume the battery will be able to take on the seasonal bump.
sotek2345
Engineering Manager
I plan on doing 90% for daily use year round. That is what Ford recommends for the Mach-e (and what we do).
