Anyone in the Atlanta area have a Sunrun install for the Pro charger?
uccbcc
Christopher
Denver
2023 F150 Lightning Lariat Avalanche
Sapper55
Frank
Canton, GA
Farmer
I used a local electrical contractor instead of using SunRun…less than half of what SunRun wanted to charge me. Located in Cherokee County north of Atlanta.
Phip ATL
Dan
Atlanta, GA
None yet
SunRun (well, a subcontractor) came out and waiting on a quote....and been waiting for a while. At this point, I'm going to let it go and start without a charger installed. I have a 50amp circuit installed for me RV and am hoping/ guessing that should be sufficient for overnight charging which is mainly what I'll need given how much I drive.
uccbcc
uccbcc
Christopher
Denver
djwildstar
Guy
Atlanta, GA
2023 Lightning Lariat ER, 2023 Mach-E GTPE
Information Security
I'm in Cobb County and had SunRun come out and give an estimate. They took so long to come out that I got estimates from Qmerit and several local electricians the same week as SunRun's estimator came out ... and I had selected an electrician and work was underway before I got a call from SunRun that their estimate was ready.
I eventually went with Powers Electrical Solutions.
djwildstar
Guy
Atlanta, GA
I had to go several weeks before I could use my Charge Station Pro (long story short, the CSP took a couple of weeks to arrive, and had a bad WiFi chip so it had to be replaced). I did just fine with a J+ Booster2 charging at 3.84kW off of a 6-20 (240V 20A) plug in my shop. The Ford mobile charge cord draws 30A from a 14-50 plug, so it charges at 7.2kW. That's about 15 miles of range per hour plugged in.
Randall Stephens
Seattle
2023 F150 Lightning Lariat ER
Jet Builder
Who did you contact about your bad charger wifi chip? Do I call ford? Do I call sunrun?
djwildstar
Guy
Atlanta, GA
Call Ford; there’s a number on the CSP instruction booklet if I remember correctly.
They had to transfer me a couple of times, but I wound up with the EV support team. They checked with the IT team and a couple of days later informed me they were going to fedex a replacement to me. It arrived, I had the electrician install it, and shipped the old one back to them.
Church
Michael
NW Tennessee
2023 Lightning Lariat Ext. range
County Health Director
I installed the pro myself with the help of a Tesla buddy and advice of an electrician, spent about 500-600 in cable and breakers. Would have been easier and cheaper but previous homeowner wired light duty wiring to the garage. Pro charger came with the 23 ER lariat.
timtim2008
Tim
Atlanta Ga
F150 Lighting XLT
Landscaping
price?
djwildstar
Guy
Atlanta, GA
The parking space for my Lightning is about 50 feet from my panel (and HIS), and I originally had it installed on a 100A circuit to support 19.2kW charging. So that install was $1250. The HIS install (including moving circuits to a critical loads panel) was just under $3000.
