ricko24
These pics are after adjusting the drop of my B&W Tow Stow hitch. Based on measurements I was told I needed a 4-5" drop. I started at the 2nd lowest pin location which was way too low and as you can see in the pic the B&W is all the way up to the 2" drop position.
The rear end of the F150 is basically level to the front end due to the tongue weight of the Airstream. Didn't think the tail end would compress that much. The airstream position is almost identical to how it was on my X5. I'm thinking of adjusting to the next notch up to see if that helps the AS get a little more level. Also the parking lot I was in did not have one good level spot. So I might be good.
I'm also thinking of replacing this 5" drop with the 3" drop version..just to get rid of the extra hang which I don't like and can get in the way in certain situations.
